It is currently Tue Jul 08, 2025 2:04 pm
PostPosted: Thu Jan 01, 2015 5:54 pm
I see a lot of ads for their use but has anybody used them on A Series?
Are they necessary to prevent roller rockers from wearing the top of a stainless valve stem (wear would be U shaped from the roller??).
Opinions and suggestions from my peers please 8)
PostPosted: Thu Jan 01, 2015 6:04 pm
I had a set of S/S inlet valves that got severely radiused by roller rockers in a very short time, so I would say, YES! Good idea.
PostPosted: Thu Jan 01, 2015 6:17 pm
Thanks again Doc. I'll measure the stems and have a look-see on the interweb.
Do you know of any stockists?
One small worry; is there the possibility they can come off?
PostPosted: Thu Jan 01, 2015 6:29 pm
Maybe a dab of locktite could help the worry?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Thu Jan 01, 2015 9:53 pm
They won't come off, think about it... the bits are all travelling in each direction, together. They are common on many more modern engines.
PostPosted: Thu Jan 01, 2015 10:18 pm
Thanks for putting that straight
PostPosted: Thu Jan 01, 2015 10:52 pm
Lash caps are designed to rotate on the valve stem too so I wouldnt be using lock tight. They sre very unlikely to come off.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Fri Jan 02, 2015 6:24 am
Minibob - there are quite a lot of the 6mm valve set-ups for A-series which use lash caps. These are normally used along with valve retainer cap which is machines to allow snug fit for the lash cap.
The standard A-series valve stem is 9/32 inch, close to 7mm.
PostPosted: Sat Jan 03, 2015 11:10 am
Thanks Carbon.
My understanding is that they go on the stem above the collett and are a push fit.
I can't go by standard measurements because the s/s valves are part of the alloy head I'm fitting. Will need to measure them.
PostPosted: Thu Jan 08, 2015 2:03 pm
I did't know what lash caps were, found this after a google search, yeah they are probably a good idea.
http://ls1tech.com/forums/generation-iv-internal-engine/1509661-public-service-announcement-w-pics-lash-caps-important.html
Nick
PostPosted: Fri Jan 09, 2015 1:57 pm
Thanks for posting the pics, very interesting to see the damage caused.
PostPosted: Fri Jan 09, 2015 2:57 pm
Regardless what was said in that LS1 forum, stock S/S valve stems are pretty soft. Good valves have hardened or stellited stem ends.
PostPosted: Fri Jan 09, 2015 3:37 pm
It was more of a what could happen, and more the photos showing, ignoring most of what they said. I assume that those pics are a good representation of what could happen?
Nick
PostPosted: Fri Jan 09, 2015 6:02 pm
Yank pushrod motors run a heap of valve spring pressure, they have to.
Never seen that sort of valve or cap damage on an A series though, worst case the end of the valve stem gets burred out a bit or gets a radius in it. Unlike most V8 motors,
A series valves don't spin, they are gripped tight by the collets. A+ triple groove collet ones can though.
PostPosted: Wed Feb 11, 2015 10:17 am
Spent lots of time fettling the nissan/datsun L20B and they use lash pads. When the pad thickness starts to get over 5.5mm they can jump out in operation. The aftermarket alloy valve caps use a very deep pocked to retain the lash pad. I source from http://www.precisionshims.com.au/ in Melb, he's a nice guy (train spotter) and works out of his shed. Last set I bought was 8 different sizes to suit the rocket/valve wear (+- 0.01mm), they will suit whatever size you want. Changing the rocker pad geometry and integrating lash pads allows you to change the acceleration path of the valve sort of like re-profiling the cam without touching it.
Just started working on a 12G940, have a set of 6mm OE valves I'll be putting lash pads on. Will be fun clearing the hurdles.
