It is currently Sun Jul 27, 2025 8:50 am
 Post subject: Body Number
PostPosted: Fri May 20, 2005 12:15 pm
I have recently bought a bare shell and am trying to work out what year it is. There is no compliance plate just some numbers stamped onto the body. There is 31535 stamped onto the fire wall and no's on the radiator shroud but I can't make these ones out. I have some pics but can't work out how to post them here. I am also concerned about getting it registered with only these no's to go on. As stated it was a bare shell so I can't go off any parts etc. Much appreciated.
Ziff
PostPosted: Fri May 20, 2005 12:18 pm
mate it shouldnt be a drama.. none of ours have plates either and loads of minis have dodgy ones.. some dont have plates at all apparently there are a lot of posts on here about this subject try the search option it may help a lot as om sure others will..
PostPosted: Fri May 20, 2005 12:23 pm
If there is no plate with the engine number, etc, you could have trouble down the track.
My car is a 61 model, and has a four digit number on the firewall, nothing near the radiator, and a five digit number followed by the four digit body number on the plate.
Has the car got wind up windows? (If the doors are original)
Roundy, clubby?
 Post subject: Body Numbers
PostPosted: Fri May 20, 2005 12:36 pm
Sorry, it's a round nose and all of the doors etc. were also stripped bare.
PostPosted: Fri May 20, 2005 12:43 pm
email sent. :wink:
Would be either an 850 or Mini Deluxe with that body number.
Is there a hole in the toeboard for an 850 magic wand shift, or a square hole in front of the handbrake?
Last edited by drmini in aust on Fri May 20, 2005 12:45 pm, edited 1 time in total.
 Post subject: Re: Body Numbers
PostPosted: Fri May 20, 2005 12:44 pm
Welcome Ziffster....the fact that the doors are missing may not be a problem because the "jambs" (for the want of a better word) are different for sliding window and wind-up.
The other thing to check is the front valance....early cars had no cut-outs on either side......
Single fuel tank?....means it aint a Cooper necessarily.....
my 850 has a two piece headlining...therefore you can see where the mounting screws have been above the B pillar....etc etc
850s had narrow brake shoes and single leaders....later had twin leading and a split system for safety etc etc
you gather all this sort of stuff together and then you start to build a picture of what you have ....couple that with the emails I sent and you just may be able to ID the car...Good Luck :D
PostPosted: Fri May 20, 2005 3:43 pm
I'm going to take a wild guess that it is an 850, perhaps mid-late 1963. Don't think its a Deluxe as I don't think the numbers went that far, but then it could be a K. If it doesn't have channels in the floorpan and it has no remote hole for the gear shift, then its an 850. If it has channels in the floorpan and no wand-change hole then its a Deluxe/K. Radiator shroud numbers on early Minis don't tend to make any sense compared to the body number - may be within 500 or so.
There are lots of giveaways - I think the holes in the rain gutters were different on 850s???? Or was that only Pommy 850s I can't remember. As Mick said - the door jams have a different size striker plate and the door buffers are the opposite way round on an 850. That is, unless the doors were converted....
 Post subject: Pudding Stirrer...
PostPosted: Fri May 20, 2005 10:15 pm
English and heritage bodies tend to have a slot drain in gutter rather than the two holes...
yeah Anto...location of gearshift is a dead giveaway.......and those pesky channels mate...
BTW when do we get a progress report on the rebuild :?: :D
 Post subject: Re: Pudding Stirrer...
PostPosted: Fri May 20, 2005 10:30 pm
Guys, the early Mini Deluxe and S had no floor channels either, until ~1966-67. They just had a little metal guard at front and back, to protect the pipes.
How do I know this? We've got one.. 8)
<edit> re Deluxe production- way more than 31,500 would have been built. I'll check the number on our `66 one tomorrow... :wink:
Last edited by drmini in aust on Fri May 20, 2005 10:56 pm, edited 1 time in total.
 Post subject: Corn Jecture....
PostPosted: Fri May 20, 2005 10:47 pm
Yep...I think we need to see photos of Zifs Mini before we are too much older...
Zif send it to me if you have trouble postin a fot :D
PostPosted: Fri May 20, 2005 11:38 pm
Have a look in here ... http://www.ausmini.com/forums/viewtopic.php?p=86794 It tells you all you need to know about getting your picture up on the forums.
Cheers Dat
 Post subject: Mini body numbers
PostPosted: Sat May 21, 2005 1:28 pm
I have just been in to have another look over the body and took some more pics. I also discovered there is no hole for the wand type gear shift and never has been. I think I've worked out how to post pics now (thanks very much) so here goes.
Front showing grill shape
Door jams
Front floor
Fire wall number
Radiator shroud number unfortunately a bit worn
PostPosted: Sat May 21, 2005 1:51 pm
in that case, I'd say mid-late '65 deluxe, I have a very early deluxe (wiper motor says 11/64, and I believe it's the original) and the number on the firewall is 24300
<edit>
yours is a MK1 shell, in that it does not have recessed wiper arm holes, and does not have the cutaways on the front scuttle panel
and it's a very nice looking shell too
PostPosted: Sat May 21, 2005 2:07 pm
<edit>
I can't see the scuttle panel that well, but a `65 should have the cutaways, didn't they come in with the 1st Deluxe? Twin LS brakes.. :wink:
PostPosted: Sat May 21, 2005 5:41 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i think that may be a late k shell bye the door jamb but of course i may well be wrong
makka
