It is currently Thu Aug 14, 2025 11:05 am
 Post subject: Front subframe movement
PostPosted: Tue Jan 06, 2015 9:55 pm
I've noticed lately that I can feel the subframe moving under my feet when I drive my car. I checked the bolts the other day and all were tight, except for the two under the pedals so I retightened them - however I can still feel the floor flexing a small amount when driving around (when not wearing shoes).
Last time I checked the floor and frame were solid in that area, though it's been a while so I'll clamber under for a look on the weekend.
Is the normal? If not, could it be related to the dual engine stabilisers I have connecting the sump to the bottom of the subframe?
(car is a 68 model, with dry front subframes)
Thanks.
:D
PostPosted: Wed Jan 07, 2015 7:36 am
Do you have the ones that bolt to sub frame bolts? If so that might be it, there's a fair bit of torque leverage through them, I prefer the double top mounts.
PostPosted: Wed Jan 07, 2015 8:19 am
No, my lower stabilisers had to have two extra holes drilled in the frame, about 4-6 inches infront of the floor mounts.
PostPosted: Wed Jan 07, 2015 9:27 am
The floor possibly needs stiffening because of the extra loads that are getting fed in that area.
BMC Australia stiffened the 1100 floor across the frame mounts.
PostPosted: Wed Jan 07, 2015 9:29 am
Floor may be cracked?
Steering Rack may be moving?
PostPosted: Wed Jan 07, 2015 9:30 am
Do the mini racers stiffen their floors?
PostPosted: Wed Jan 07, 2015 9:39 am
Ill look into strengthening and for cracks- but wouldnt have thought a standard 50hp engine would be enough to do anything......but with a 47 year old car its a lot of work over time in that area.
Ill check the rack too thats a good idea, but theres no movement in the kickpanel so im hoping thats fine.
PostPosted: Wed Jan 07, 2015 11:45 am
If the 6 nuts and bolts are tight and the 4 tower top studs or bolts are tight then its time to look for cracks. Most common is the welds on the tower tops.
PostPosted: Mon Jan 12, 2015 12:10 pm
Well I finally pulled up the carpets and climbed under the car for a look - no cracks in the subframe or body regions, which is good. I then checked all the nuts for tightness and though not movable by hand, with a spanner on them the tower studs moved more than I'd have liked - so all tightened up now to something far more solid.
I also replaced the washers on the floor mounting bolts with bigger ones as the ones I took out have deformed in shape a bit.
Took the car for a drive and no movement now - all fixed.
:D
PostPosted: Mon Jan 12, 2015 12:54 pm
Years ago when I tracked mine I found the 4 floor bolts used to work loose. So I fitted locknuts, problem solved. You could use nyloc nuts instead.
PostPosted: Mon Jan 12, 2015 5:56 pm
Some do.
Users browsing this forum: No registered users and 283 guests
