It is currently Sat Jul 26, 2025 10:24 pm
 Post subject: How much is too much
PostPosted: Fri May 20, 2005 12:36 pm
Quick question i have two minis ones a work car has a fair bit of rust
When is there too much rust to bother getting removed and just buy a better shell
I know anything can be done but i would have to pay someone to do the work and theres rust bubbles comming up on a few different areas
In the gutters on the roof, the seams down the side, doors and the paint is starting to bubble in other places it only a clubman s so would i be better off buying a better mini to start with
I want it as a weekend car and a car that one day i can do some track stuff in
 Post subject: Structural
PostPosted: Fri May 20, 2005 12:56 pm
For the track, depends on whether it is structural....so sills would be really good place to check...otherwise if it is cosmetic....well that can be treated and protected.
PostPosted: Fri May 20, 2005 1:14 pm
yeah structually it is all good the underside and sills are great no rust due to being painted in some black thick stuff by the looks
its mainly cosmetic but lots of time/labour needed to get it perfect i feel the roof will need a new skin
i quess its a tough question with out seeing the car i just feel unless its a copper of a LS or something probably not worth the 3 grand labour bill just after thoughts experiences
 Post subject: Up on the Roof....
PostPosted: Fri May 20, 2005 1:19 pm
The roof on a Mini is a structural componenet...it ties all the pieces of the mechano set together...are there actual holes in the roof??
PostPosted: Fri May 20, 2005 1:22 pm
well no but at the back along the gutter there are nasty rust bubbles
PostPosted: Fri May 20, 2005 1:30 pm
marc i'd take a screwdriver to that black thick stuff
there might be rust under it
as i found out in my mini
i dug it all up, primed and painted over
Inconspicuously Conspicuous
PostPosted: Fri May 20, 2005 1:36 pm
what i am thinking of doing is taking the car off the road stripping it and taking it to a pro but what have you guys found the price of rust removal to be
it seems like something that would take a while to do properly
PostPosted: Fri May 20, 2005 1:41 pm
if it's just fairly small bubbles, then there's a good chance it's only light rust underneath - the only way to tell is to take the paint off - use a screwdriver again, just pick away at it, you'll probably find that it's just heavy surface rust under there. Holes in the roof, I'd go with another shell, holes in the seams, I'd fix them
Sills rust from the inside out, so even if there isn't external evidence, they may be rusty inside, and so may any other shell you buy - could be 'better the devil you know'
PostPosted: Fri May 20, 2005 1:42 pm
Marc, getting a pro to fix it up will cost you a bucket load of dollars.
I have a very nice straight Deluxe, have a look in the for sale section. Probably around page 5 or 6 by now.
Had enough of the bitching, off topics and Pings on MiniMania and seen the light and come here hey Marc?
PostPosted: Fri May 20, 2005 1:49 pm
yeah mate i have been here for a bit now minimania has lost me i dont get to spend much time on here either though due to work but this site is sooooooooooooooooo much better and people here i can relate to
pitty minimania used to be unreal
i will check the delux now cheers
 Post subject: Cheap Bundy anyone?
PostPosted: Sat May 21, 2005 12:44 pm
welcome...svenson...introduce yourself here... :D
http://www.ausmini.com/forums/viewtopic ... &start=795
Users browsing this forum: Bing [Bot] and 103 guests
