It is currently Tue Aug 05, 2025 9:51 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 18, 2015 4:20 pm
min are vented..
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Sun Jan 18, 2015 4:38 pm
Right -o. Here's what you need for a complete setup then:
(Calipers and discs you have, I'll ignore rebuild parts for the calipers)
Normal stuff:
-Mini disc brake hubs, complete with mini steering arm and balljoints.
-Tapered wheel bearings (as always on disc hubs).
-Mini disc brake CVs.
Special stuff:
-METRO type drive flange. These are different to mini ones as they are a 1/4inch wider to make up for the thickness of the vented disc.
-M10 x 1.5p hex head set screws (grade 10.9) to attach drive flange to disc. Socket head cap screws won't work as the counterbore isn't deep enough.
-MG metro turbo caliper bolts from minispares: These are special bolts that are 3/8unf thread, but with 10mm shank and are coated in an anti-vibration paint. You need 4, but order 6 - when you get them you'll know why.
-Metro brake pads and retainer clips.
-A way to adapt the dual brake circuit to single. You can buy a kit from overseas but I don't know if its ADR approved - most people just put a tee fitting in there with a banjo bolt and pipe directly to the other one.
PostPosted: Sun Jan 18, 2015 4:41 pm
perfect
cheers..
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
