It is currently Fri Aug 01, 2025 3:35 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: speedo error
PostPosted: Sun Jan 18, 2015 7:01 pm
998 Clubbies all had timing marks on the timing cover.
Good idea, we can see them. No mirrors or gymnastics required. 8)
PostPosted: Mon Jan 19, 2015 4:12 am
But this engine is supposed to be a 1275,I suppose the timing cover fit all mini engines.
Hi 9YaTaH,I am retired now so I have all the time in the world to play with my cars.
This mini was my last aquisition and I am trying to get it right,I won't let it beat me.
Regards Felix
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Mon Jan 19, 2015 7:25 am
1275LS had the marks on the cover too. As did all later engines from UK.
Whenever I rebuild a motor (with lightened flywheel) I braze a steel pointer onto the cover, and file a TDC mark on the pulley. Then use a dialback electronic timing light to set advance accurately.
PostPosted: Mon Jan 19, 2015 8:41 am
Regards Felix
The main problem I see for Felix, is how do you schedule driving 8 cars into a 7 day week...I wouldn't mind having to deal with that "problem" though! :D
PostPosted: Mon Jan 19, 2015 10:48 am
The mini and mgb are on club plates and the others except for the mazda are on limited usage with shannons.I figure I have 1 car for each day of the week plus a spare.My wife reckons I have a problem.
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Mon Jan 19, 2015 10:54 am
Odometer reads 0.3km low for every 1 km on the navman.
And as said before the speedo is reading 10 km low for all speeds.
Therefore it must be the wrong speedo drive fitted to g/box.
Does anyone know what size or P/N drive gear I need to fit to g/box to fix this problem when I eventually pull motor out.
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Mon Jan 19, 2015 11:08 am
Try this website, it's UK based
http://www.guess-works.com/Tech/ratio.htm
Users browsing this forum: Bing [Bot] and 87 guests
