It is currently Sat Jul 26, 2025 10:52 pm
PostPosted: Sat Jan 17, 2015 11:36 am
Hi all,
I'm using a fuel tank clean and restore kit.
Step 1 is clean - done
Step 2 is prep the metal - done
Step 3 is coat the product on the inside walls of the tank.
BUT - I note this fuel pickup pipe which will lays at the bottom of the tank.
So I can't coat this or it will not function. I can remove it (even that may be difficult) but I don't think I'd be very easy to re-install!
Any advice?
PostPosted: Sat Jan 17, 2015 12:25 pm
You can just remove it but make sure you install a good inline Fuel filter "Before" the Fuel Pump.
"Let us remove your "SHORTS"
PostPosted: Sat Jan 17, 2015 12:48 pm
Thanks so much for answering - and quickly! I'll remove it and apply the sealer. Needed to get an external opinion, cheers.
PostPosted: Sun Jan 18, 2015 3:02 am
Morbo, this topic was also discussed on Mk1 Forum couple of weeks back : http://mk1-forum.net/viewtopic.php?f=3& ... ank+sealer
PostPosted: Sun Jan 18, 2015 8:05 am
Wow that is exactly the same issue, thanks Carbon lol :) I guess there are no new questions when it comes to minis :)
I maaaaaaaay have just gone ahead and sealed it anyway...
I discuss it in my post in the build thread if mildy interested (clicky)
As you can see here:
Mine ended up getting covered in it. I blew compressed air through there multiple times when drying, which seemed to keep if free of paint and there seemed to be almost no resistance to the air. But I will test it today now it's sat overnight. I expect I may have to deal with in in some way, surely that is blocked to some extent.
PostPosted: Sun Jan 18, 2015 3:37 pm
How did you paint the inside of the tank?
PostPosted: Sun Jan 18, 2015 3:45 pm
Used the POR15 system. Clean, then Prep, then Paint.
The paint step involves pouring it in, sealing the holes and rolling it around to ensure full coverage.
PostPosted: Sun Jan 18, 2015 4:01 pm
Also by the way there is more info in the build thread - link posted a few posts up.
PostPosted: Sun Jan 18, 2015 7:47 pm
Oh ok, I thought you somehow used a paintbrush and I couldn't figure out how you got your hand in there.
Thanks
PostPosted: Mon Jan 19, 2015 7:00 am
Thanks
He has small hands.....really small.
PostPosted: Mon Jan 19, 2015 8:18 am
why do you want to seal it, it looks fine, or am I missing something.
PostPosted: Mon Jan 19, 2015 1:02 pm
What he said. It looks so clean in there, unless there are pinholes I'd leave it like that. Thats what mine looks like in the Traveller since I recently cleaned it. It lasted 50 odd years without a coating in there, I reckon it will go another 50 now.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Jan 19, 2015 9:03 pm
Fair question! There was heaps of crap in there - it sat unused in a shed for 15 years. I expected it to be worse than it was, given the state it looked to start with. So I ordered the kit.
After cleaning it I considered leaving it at that, as it came up really well. But this is a full nut and bolt resto I'm doing, so I wanted everything to be as schmick as I could get it.
I'm sure leaving it would have had no bad outcome; and I wouldn't be pissfarting around trying to remove an itty bitty pain in the arse filter screen :)
