It is currently Wed Jul 23, 2025 7:53 am
 Post subject: GR cams
PostPosted: Tue Jan 20, 2015 12:56 pm
Just wondering if GR used to do like generic cam grinds back around 2000/2001? Did he have a general grind that he would do for most road going 1275-1330's etc? Or was each big block cam done differently?
I had my 1275 cyl head ported and hardened valves seats fitted by GR and he also did grind on my camshaft at the same time. Unfortunately I never received an invoice or spec sheet etc which outlined the cam specs.
I understand GR is hard to contact so didnt want to go calling him up 15yrs later with a random question. Just thought others may know.
 Post subject: Re: GR cams
PostPosted: Tue Jan 20, 2015 2:11 pm
Call him. The only reason he may be hard to contact is if he's out of hearing range of the phone or away from his workshop. I spoke to him this morning. As always he was happy to talk and give advice. I'm guessing he'll remember your job as he has a sharp memory.
PostPosted: Tue Jan 20, 2015 5:00 pm
viewtopic.php?f=2&t=88360
PostPosted: Tue Jan 20, 2015 6:13 pm
He sometimes marks the cam with the grind spec (i.e. RE13). Knowing how meticulous you are with photographing your restos, maybe you have a pic from back then that shows the mark?
PostPosted: Tue Jan 20, 2015 9:04 pm
Unfortunately I didn't own a camera back then. Digital cameras were not exactly affordable in 2000. I used to use my parents Kodak when I was living at home and first started the resto. But once I moved out, mini parts were more of a priorty then spending money on a Kodak camera.
I feel silly hassling GR with a random phone call about a minor job 15yrs ago....
