Thanks for the reply guys. And yes Winabbey, I have certainly bookmarked and read your awesome transmission build scans. I must've skimmed over the quick word about removal, and it still doesn't sit too well with me. ("...once you've knocked out the 1st motion shaft bearing with a drift...")
So, using this diagram for clarity (as it has nice numbers pinned all over it).. http://www.miniclassics.co.uk/mg/pages/info1.htmThe "First Motion Shaft" is the piece labeled #1 & #2. I can't see any way you might get a drift in between the trans case and the bearing, but maybe I am missing something.
The other thread shows a piece of square steel with a slot cut in it, but I am missing something here as well. The bearing is in the case, with a shaft coming through it. How would I "slip this
over the bearing". And even if I did, winding in that bolt (from the photo) would only push the first motion shaft further inwards. Perhaps the bolt is there for illustration only? And the welded bolt is the correct size to thread onto the first motion shaft?
So far the only suggestion that seems to make sense is Simon's. It sounds like I put the bolt back onto the first motion shaft, attach a slide hammer, and start drifting out the bearing. This sounds to me like a lot of force and potential damage to the first motion shaft. But if that's the way to go..... Just say the word and I'll start slide hammering away.
Sorry for the ignorance, I don't know why I'm having such a hard time wrapping my head around this one.
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
