It is currently Wed Jul 23, 2025 11:21 pm
PostPosted: Sat Jan 24, 2015 1:19 pm
I am currently in the middle of my gearbox rebuild and everything has gone together fine so far however I have checked the gap between the 3rd motion bearing retainer and the gearbox and without any shims the gap with feeler gauge is only about 2 thou of an inch. In some places around the retainer I can't even get the 2 thou feeler gauge in.
Would this be an acceptable amount of clearance to retain the 3rd motion bearing once the retainer is tightened?
1963 Morris 850
PostPosted: Sat Jan 24, 2015 1:51 pm
Yes. It will be fine.
Contrary to the belief of some, putting more shims gives less preload against the bearing's circlip. Because you are shimming the retainer out.
PostPosted: Sat Jan 24, 2015 2:01 pm
Thanks Doc
1963 Morris 850
Users browsing this forum: No registered users and 118 guests
