It is currently Wed Jul 23, 2025 7:13 pm
 Post subject: Help removing cone/donut
PostPosted: Sat Jan 24, 2015 5:15 pm
Im trying to get the cone compression tool down the top to screw in and it doesnt seem to want to grab on anything. All i can see in is these 2 photos but i have no idea how it should look? Could someone please give me a idea if this is right?
PostPosted: Sat Jan 24, 2015 5:38 pm
Sometimes the hole/thread can get really ugly, so much that it can be so full of rust and sh*t that a thread tap is required. this presents problem number 2, get a tap down there. You'll need to braze one onto a bit of rod with T on top.
Might sound a bit rough, but usually when they're this bad the cone is stuffed too, I get stuck into cone/trumpet with an air chisle then bin the whole lot. Are you fitting hi lo's or something?
PostPosted: Sat Jan 24, 2015 6:10 pm
yeah gonna fit hilos and new cones.
I havent got a air chisel lol.. ill have to work something out tomorrow
thanks peter
PostPosted: Sat Jan 24, 2015 6:24 pm
They should just drop out the bottom with the trumpet still stuck to it thats what happen with me
I only needed to compress the cone when i put the new ones in
PostPosted: Sat Jan 24, 2015 6:28 pm
Online
If you have no air chisel an angle grinder will do. :twisted:
PostPosted: Sat Jan 24, 2015 7:41 pm
I got one of them.
Thanks kevin..
And thanks for earlier too
PostPosted: Sat Jan 24, 2015 7:55 pm
try a long punch and hit cone about 50mm up from bottom of alloy section.
PostPosted: Sat Jan 24, 2015 8:07 pm
I did mine recently and only needed the compressor when fitting in new cones.
Remove that square rubber stop for some space as top arm has to come out - check condition of pin and bearings. Lever pin from front. Change the knuckle joint too if needed.
Other than cone compressor, you may need a ball joint splitter.
PostPosted: Sat Jan 24, 2015 8:37 pm
Online
If you want to replace the top bearings, they are a bugger to remove. But I have a new puller that works, bring em over.
If the top shafts are not worn, keep them. Their material & hardness is way better than the aftermarket ones being sold now.
PostPosted: Sat Jan 24, 2015 9:12 pm
Both pins/shafts and bearings were good doc.
Just to clarify stib, top arms gotta come out for new stuff to go in.
PostPosted: Sat Jan 24, 2015 9:24 pm
Online
Sorry Fishy, I was aiming that post at iamstib. :wink:
PostPosted: Sat Jan 24, 2015 9:35 pm
Once i get them out ill send you a photo kev and u can tell me what u think cuz ill prob have no idea lol.
Thanks for the help gents.
Users browsing this forum: drmini in aust and 110 guests
