It is currently Sat Jul 26, 2025 10:14 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 20, 2005 7:56 pm
A car with a blocked fuel filter may run fine on flat ground and on downhills but as soon as you look at a hill it will start to hesitate.
To check if the car is out of fuel, undo the 3 screws on the top of the float bowl on the carby, remove the top and the bowl should be about half full.
If you want to see it you have a fuel blockage or if you want to check that the fuel pump works, take the hose off the top of the float bowl and stick the hose into a clean bottle (600ml coke bottle will do) If you have an electric fuel pump turn the key on and it should start to pump fuel into the bottle. If you have a mechanical pump you need to wind the motor over on the starter and it should start to pump.
If the pump is not working and you need to move the car you can tip fuel into the float bowl (after removing the top) and you can drive for about 30 seconds. :wink:
PostPosted: Fri May 20, 2005 8:27 pm
Well, I'm an idiot.
The car was out of fuel.
I guess 100 miles is out of range from a full tank.
I'm still going to check the lines for leaks, just caus I could smell fuel the other day.
I'll check the pump too, it doesn't sound too healthy.
Thanks for all the help guys.
:oops:
PostPosted: Fri May 20, 2005 8:37 pm
1) The car should get a lot more that 100 miles per tank.
2) If you can smell fuel you probably have a leak (see # 1)
3) The pump will make a lot of noise when it is empty. (see #2)
4) If you don't know how old the rubber hoses are change them.
5) If you do know how old the hoses are change them anyway!
:lol: :lol: :lol:
How old are the brake hoses?
PostPosted: Fri May 20, 2005 8:46 pm
General rule: if in doubt, change it!
PostPosted: Sat May 21, 2005 2:44 pm
I would also put a Fuel Filter before the Electric Fuel pump also :wink:
