It is currently Sat Aug 09, 2025 7:40 pm
PostPosted: Sat Feb 07, 2015 1:23 pm
Hi,
My Battery recently died and I replaced it. I was checking the charging system and it seemed ok. I checked it again the next day and at idle the battery was reading about 15 to 16 volts, when I bought the revs up it went up to about 17 volts, way to high. I think thats what cooked my last battery as it wasnt very old. I have a 15AC alternator, the external reg isnt a mini one. Would the problem more likely be the reg or the alt as i have about 3 other alternators i can use, all 15AC but I dont have any spare regs.
Thanks
Steve.
PostPosted: Sat Feb 07, 2015 1:49 pm
Regulator.
PM `convertible mini', he's the resident autoleccy on here and has new regulators.
PostPosted: Sat Feb 07, 2015 5:49 pm
Thanks Doc, I messaged Convertible Mini, hopefully he can help. Otherwise I guess I could just get a internally regulated alternator.
Steve
PostPosted: Mon Feb 09, 2015 2:46 pm
In a PM You asked me for a regulator! I replied asking what alternator you have and you did not reply. If it is an external Regulator you are after for a 69-71 car. I do not have any. I do not get enough call to warrant me making a good order to get them for a reasonable price. You might be lucky enough to find a good second hand one.
Would be cheaper to buy a new Alternator unless your car is being kept original.
"Let us remove your "SHORTS"
PostPosted: Mon Feb 09, 2015 3:26 pm
Ok thanks mate, didnt recieve your PM. I think I may just get a new alternator, it is far from original, so thanks for that.
Steve.
