It is currently Tue Jul 15, 2025 9:50 pm
 Post subject: Inlet manifold
PostPosted: Sat Feb 07, 2015 5:51 pm
I have a Leyland? Inlet manifold and I am going to replace the 1-1/2" SU with a 1-3/4" SU.
Should I invest in a Minispares (or similar) manifold and will the Ramflo air filter fit OK as these inlet manifolds are longer.
 Post subject: Re: Inlet manifold
PostPosted: Sat Feb 07, 2015 6:12 pm
A Minispares single HS4/HS6 manifold fits, however you will probably not be able to run the donut air filter.
Fit a Ramflo, K&N or similar sports filter.
Here's my 1412 stroker with a 20mm thick spacer on it:
PostPosted: Sat Feb 07, 2015 6:45 pm
Is there a significant benefit of the Minispares manifold over the Leyland even if the leyland one is ported as DVD A Series book.
PostPosted: Sat Feb 07, 2015 9:12 pm
A lot less work to fit, and they are pretty cheap to buy, even here. I'd say they will outflow a ported stock HS4 one.
PostPosted: Sun Feb 08, 2015 7:31 am
That's NOT a stock HS4 cast iron manifold.
That looks like the MG metro manifold, it's alloy and flows pretty well according to Viz. I doubt you'd get much (if anything) going to a minispares manifold over that.
cheers,
Jacob
PostPosted: Sun Feb 08, 2015 8:09 am
Looks the same as the one I bought second hand from the UK. And you can see the grooves in the photo that indicate that a 44 (1 3/4) has been previously bolted up.
Mine looked as nice inside as the much shinier (and expensive) Mspares version...
Cheers, Ian
PostPosted: Sun Feb 08, 2015 7:35 pm
Looks like the MG Metro manifold. Build for the HIF6 and flows very well. No need to change.
M
Users browsing this forum: timmy201 and 106 guests
