It is currently Tue Jul 08, 2025 6:56 pm
PostPosted: Mon Feb 09, 2015 4:11 pm
Garagedefend wrote:
where would I find that?? lol
Its under the gear knob son! :lol:
[look underneath, to where the rod change comes up through the floor. Should see a rubber block]
PostPosted: Mon Feb 09, 2015 4:24 pm
You don't seem to be too far away if you're near the ACT.
You would be welcome to drop around for a look.
PostPosted: Mon Feb 09, 2015 4:39 pm
It is a Matic, it won't have a gear change mount problem.
It should have Hardy-Spicer uni joints on the inner ends of the driveshaft.
PostPosted: Mon Feb 09, 2015 5:00 pm
Matics are more likely to have an engine mount problem than a manual, as they only have 1 engine steady. They tend to move >hard in one direction when you select a gear from neutral.
Note these mounts are both different to manual ones.
If thinking about adding a top steady, note the engine is 20mm? further forward than manuals are, so you would need a longer steady bar or a custom bracket.
PostPosted: Mon Feb 09, 2015 5:36 pm
My top shock mount came loose and bugged me for years trying to work out where it was coming from. Grab the shock and try and move it. Worth a try. :wink:
Aaron
PostPosted: Mon Feb 09, 2015 6:14 pm
Possibly a loose steerting rack u bolt.
PostPosted: Mon Feb 09, 2015 8:09 pm
When I go from neutral to drive it does clunk quite loudly!!
Only when hot though. cold it shifts slow enough lol
PostPosted: Mon Feb 09, 2015 8:10 pm
Mick will pm you. I'm too embarrassed tho lol
PostPosted: Mon Feb 09, 2015 9:31 pm
Check the idle speed, on a `matic it should be 650rpm according to the manual. I would say this is in neutral.
If too high, it will clunk more when shifted into gear.
PostPosted: Mon Feb 09, 2015 10:10 pm
almost certain my idle is low. although I have not put a tacho yet.
on idle the filter light comes on. lol
PostPosted: Mon Feb 09, 2015 10:14 pm
There is no filter light switch on a matic.
And the auto's HUGE oil pump supplies heaps of oil to the `box and motor, so it's not low oil pressure. It is probably the generator or alternator charge light.
PostPosted: Mon Feb 09, 2015 10:22 pm
probably. theres filter written beside so I always thought it was that LOL
sometimes its on sometimes its off at idle .
PostPosted: Tue Feb 10, 2015 8:56 am
Lamp is probably put in the wrong spot in the speedo.
Oil pressure light (early matic only) should be orange, charge light is red, high beam is blue. As I said, filter light not used on a matic.
Mk2 matics have an oil pressure gauge and no warning light.
[edit] If it's an early Matic (speedo only, no oil & temp gauges), it has a generator not an alternator. These charge poorly or not at all at idle, so it's normal for the charge light to blink a bit.
Last edited by drmini in aust on Tue Feb 10, 2015 5:55 pm, edited 1 time in total.
PostPosted: Tue Feb 10, 2015 5:44 pm
Looking at your earlier photos, may I suggest you get the ball joints greased. They look a little dry
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Feb 10, 2015 7:39 pm
I had a knock in the front end when I took off and over bumps etc.
Turns out I had a loose tie rod and it was moving back and forth.
Maybe check the nuts on the front of those.
1977 Leyland Mini Van - Sold
