It is currently Thu Jul 17, 2025 7:14 am
 Post subject: Coilovers
PostPosted: Mon Feb 09, 2015 11:52 am
Anyone bought or done a coil over conversion
Do they handle well ?
Any details or info would be great
Thanks
 Post subject: Re: Coilovers
PostPosted: Mon Feb 09, 2015 3:09 pm
Yup. Got protechs from the uk. Love them.
I dont like oil leaks
PostPosted: Mon Feb 09, 2015 3:11 pm
PostPosted: Mon Feb 09, 2015 3:38 pm
rears too? or just fronts?
PostPosted: Mon Feb 09, 2015 7:04 pm
Both front and rear. Built new strut towers for the rear and converted to a beam set up.
PostPosted: Mon Feb 09, 2015 7:07 pm
PostPosted: Mon Feb 09, 2015 8:12 pm
very cool - and handy as a wedding car for lesbians when gay marriage is legalised
PostPosted: Tue Feb 10, 2015 10:13 am
So do you always have to modify the rear towers to fit coil overs?
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Tue Feb 10, 2015 11:01 am
No, you can get shocks with offset tops, but they're not as good as turretting the rear to fit them properly as done above. Makes them stronger too.
PostPosted: Tue Feb 10, 2015 3:59 pm
Are the turrets just set up vertical to the bottom mounting location or do they need to be set on an angle?
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Tue Feb 10, 2015 5:20 pm
Mine were set up vertical. No need to make angle changes.
PostPosted: Wed Feb 11, 2015 6:19 pm
Just looking into front coil overs at the moment - can I ask anyone in the know if you have to have 13x7 wheels?
PostPosted: Wed Feb 11, 2015 7:42 pm
that's a really good question, but the offset of the wheels might be more the issue
my assumption would be that fronts are OK, but rears could cause problems...?
PostPosted: Wed Feb 11, 2015 7:46 pm
You're right Simon - In my case I have 13x7 -7s, and 13x6 +15 wheels as a backup - a difference of 34mm where the shock absorber is!
Doesn't look like there's that much space in the pics above - and he has metro brakes!
PostPosted: Wed Feb 11, 2015 9:32 pm
this is an interesting read.. http://www.turbominis.co.uk/forums/inde ... tid=573892
Users browsing this forum: No registered users and 68 guests
