It is currently Wed Jul 23, 2025 7:21 pm
 Post subject: Oil leak :(
PostPosted: Thu Feb 19, 2015 7:44 pm
Ok guys so me and my brother pulled both my motor out and his motor out to fix oil leaks on mine and change his gear box. I replaced all gaskets I thought were leaking and put back in also painted motor while it was out. I finished putting it back in today after work and noticed yep it's leaking oil but from a very weird place on the drivers side gear box there r 2 bolts with copper washers under them and they r leaking is it just a matter of undoing them and replacing washer r they holding anything in under them ??
 Post subject: Re: Oil leak :(
PostPosted: Thu Feb 19, 2015 9:48 pm
Online
There is a detent spring and a steel plunger in there.
Just unscrew, fit new soft copper washer instead of old one, push in against spring, tighten up. All good. 8)
PostPosted: Fri Feb 20, 2015 4:39 am
I take it I have to drain oil
PostPosted: Fri Feb 20, 2015 9:36 am
Online
Not if you are quick. It will only drain very slowly out of there if the plunger stays in.
Users browsing this forum: Bing [Bot], drmini in aust and 103 guests
