It is currently Wed Jul 23, 2025 8:02 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sat Feb 21, 2015 7:42 am
Do not use heavy grease (eg HMP) in the rack, it will slow it down in winter.
A bit of LMM molygrease works fine.
When refitting the wheelboxes, try and have the spindles 180deg when assembled from where they were. You are then using unworn teeth on the gears. Less flop in the wiper arms.
PostPosted: Sat Feb 21, 2015 7:46 am
H2's right about fuel pipe. They used mini style wiper set ups on lots of vehicles/kit cars etc, because you could mount wheel boxes where you wanted them, the motor where convenient, then join the whole lot together. You could get different length cables and different arc angle links/wheels.
PostPosted: Sat Feb 21, 2015 9:23 am
Im about to tackle this job. Dreading it. Will update anything I find that helps in removal.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
