It is currently Fri Jul 18, 2025 9:44 am
Post new topic Reply to topic  [ 122 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: Car trailers
PostPosted: Sun Feb 15, 2015 7:33 am
The picture above with the pickup on it seems ok at a glance, but you would hope for a remote control to operate the lowering as the wheel is right where the door is!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Feb 15, 2015 9:50 am
peterb wrote:
Monaco wrote:
low n blown wrote:
I've been through all of this as well. I started with a very light 3mx1.5 that I sold to someone on here. Brilliant trailer, towed well and you hardly knew it was behind you. Was bare bones and weighed less than 300kg on single axle. Downside, nowhere to store anything. You cannot possibly make a trailer that will tow a mini and stay under 750kg, but I would love to be corrected if thats possible.
I think this is Greg's old trailer, I kept a photo as it looked light weight which is great!
So, is this trailer 3mtrs long, or am i mixing up trailer/ post description.
What's the dimensions of the steel you used? Main frame and ramps section and draw bar?
PostPosted: Sat Feb 21, 2015 7:49 am
I've started the build and will put pictures/ dimensions/ plans etc on another build thread, save making this one too long.
PostPosted: Sat Feb 21, 2015 9:06 am
If anyone wants one built, I don't have a heap of work on and am willing to make one for whom ever wants to supply/ pay for the materials and drawings of what they want. It'll cost a heap less than getting a trailer mob to make one. PM me if anyone is interested, I'm on the Gold Coast
Life's a garden.... Dig It!
PostPosted: Sat Feb 21, 2015 12:36 pm
If you are willing to put your mini on the trailer backwards, you could have the trailer axle in line with the jacking point on the mini (approx balance point) and the tray could then be the minimum length to suit a mini and the longest part of the tray is forward of the axle and therefore compliant to regulations.
PostPosted: Sat Feb 21, 2015 1:31 pm
You can put it on forward, axle in line with jacking point, you just make load area forward. Bit hard to explain.
PostPosted: Sat Feb 21, 2015 2:11 pm
Will the point for the tie downs as you mentioned pass as being part of the trailer bed?
PostPosted: Sat Feb 21, 2015 2:26 pm
They work it out on the total length of the load area, the box is a load area.
PostPosted: Thu Mar 12, 2015 8:53 pm
This one looked the goods. Tare 180kg with brakes and 1400kg rated. 3m x 1.5m tray. Just made for a mini!
http://www.ebay.com.au/itm/Trailer-3000 ... true&rt=nc
Cooper S Mk2
Cooper S Mk1
PostPosted: Fri Mar 13, 2015 7:40 am
Best Mini car trailers I've seen are the alloy tilting ones used by David Wheatley and Chris Collett for their Nb cars.
They are light, tow great and can be folded in half for storage.
I drove Chris's XR6, Mini and trailer part of the way back from PI on Monday. Couldn't notice it was there (except in rear mirror view). Am very impressed. :)
PostPosted: Fri Mar 13, 2015 9:00 pm
Very nice of you to say Doc,
I was very impressed with the car trailer - and the co driver mate
Thanks for sharing the drive. :D
Chris
PostPosted: Fri Mar 13, 2015 9:16 pm
No worries Chris, thanks for the ride to PI and back. :D
PostPosted: Fri Mar 13, 2015 9:55 pm
Do you have any pictures of the trailer and its special features
PostPosted: Sat Mar 14, 2015 8:25 am
Ill get onto it you cruiza, might need to be patient whilst I get some photos together.
Chris
PostPosted: Wed Apr 01, 2015 7:51 pm
Trailer rear section is hinged and folds onto the front for easy storage. Tail lights and number plate are fitted to a portable light board which can be moved from the middle to the rear. Image
Unfold the trailer and lock in the latch to secure front to rear. Image
Finally release the latch on the front of the trailer to tilt the trailer and drive on - ratchet down straps over the front tyres.
