It is currently Sat Jul 19, 2025 7:10 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 25, 2015 10:24 am
My centre strap is just a lump of steel stick machined and drilled.
Nothing extremely fancy.
As for the 1100 cap I dunno.
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Wed Feb 25, 2015 10:36 am
The pickup hole is for a strainer bracket, used only on nth/south engines.
Straps are generally a square section (cheapo?) steel bar, bolted on with the cap machined flat first.
I made my own from tuff EN25 for the 1412 stroker, but I shaped it to fit onto the standard cap.
Like this-
Note the strap is a little short- it's all the EN25 offcut my mate the toolmaker had. Works fine, it's now in Gafmo's van.
PostPosted: Wed Feb 25, 2015 11:34 am
Cheers guys,
I wanted to ensure when i bolted it up i didn't go covering something i needed later and that once i had machined down the cap it still had enough gap for the crank thrust washer locator..
pic is appreciated..
Darcy
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
