It is currently Fri Jul 18, 2025 7:16 pm
 Post subject: Timing in Cam
PostPosted: Wed Feb 25, 2015 8:58 pm
Hi Everyone.
I built my motor 5 or so years ago and it ran fine. However i never timed my cam in when i built it.
Now i am swapping everything over to a different shell im wondering if it is advised/possible to do this while the engine is out.
Is it possible to do this with the head on? Can you get an accurate TDC reference through the spark plug hole?
Thanks
Richard
75 Panel van, 1360, RE-13, 1 3/4su
 Post subject: Re: Timing in Cam
PostPosted: Wed Feb 25, 2015 9:15 pm
Yes you can. Use a pushrod or similar through the sparkplug hole. All you need to do is make sure that the rod moves relatively freely by positioning the dial gauge carefully.
PostPosted: Wed Feb 25, 2015 9:47 pm
Could you use the mark on the flywheel for TDC?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Feb 25, 2015 9:53 pm
There is a good explaination of how to do cam timing from the Doc in this thread.
viewtopic.php?f=2&t=87658&hilit=cam+timing+set
Handy bit of info.
5/72 Clubman Gt
PostPosted: Wed Feb 25, 2015 10:27 pm
Its better to use the micrometer. The lobe center may be out from the aligned flywheel TDC.
PostPosted: Thu Feb 26, 2015 8:46 am
Awesome, thanks mick.
And perfect scoop, that was my next question. Now to rustle up a timing wheel :D
PostPosted: Thu Feb 26, 2015 4:18 pm
viewtopic.php?f=2&t=86234&hilit=timing+wheel&start=0
PostPosted: Thu Feb 26, 2015 4:47 pm
Perfect!
Thanks Fang.
Users browsing this forum: No registered users and 121 guests
