It is currently Fri Jul 18, 2025 9:13 am
PostPosted: Sat Feb 14, 2015 7:41 pm
I have been trying to get hold of oversize inlet valves without much success...
Anyone know of a source of inlet valves with 38.1mm head diameter and the 9/32 inch stems? The only ones I have found so far have 6mm stems.
Going by GR's recent comments the 6mm stems may not be the best choice, as the heads of the inlets are almost kissing the exhausts.
PostPosted: Thu Feb 26, 2015 1:39 am
Hi,
I have some Paul Ivey 37.7mm 9/32" u/c stems.
Breaking heaps of stuff isn't the same as R&D since the "R" implies you actually did some research
G&H is the most applied practice by performance engine builders
G = Guess & H = Hope
PostPosted: Thu Feb 26, 2015 8:00 am
Thanks for the update, I spoke with Paul Ivey a few weeks back and he reckoned he last made/sold some of these large valves about 15 years ago...
Are they marked up with the REC111 part number on end of the valve stem?
PostPosted: Thu Feb 26, 2015 12:05 pm
Had them for a few years.
Part No. REC - 118
Users browsing this forum: No registered users and 26 guests
