It is currently Sat Jul 26, 2025 6:30 pm
PostPosted: Tue Dec 30, 2014 8:52 pm
I thought I'd have a go at making a Hydrolastic pump as per Micks How to. But as advised by Mick the grease barrel pump that he used had disappeared from ebay, so I stumbled across this. It is a plumbers leak test pump that I got from ebay from this store, http://stores.ebay.com.au/entropyonline/, it was $110 with free freight. The low loss connector is the same as Mick used, but I got mine over the counter from here; http://www.airtecdirect.com.au/products ... uck-h-556/
The fitting to connect them together is available from any fitting place. The fluid that I used is as pictured and recommended by Dr Mini. I think it is mixed 50/50 with demineralised water. The pump its self is very well built, it has 2mm thick steel sides, the pump is stainless steel and has replaceable seals available from any o ring and seal supplier. It has a tank capacity of 10 litres which is a bit of an overkill for what I need, but it was the rating of over 700psi that I was interested in. I was naturally assuming that the Chinese would over estimate the capacity of the pump. When I use it I put a piece of wood at the back of the pump to tilt the liquid down towards the pickup tube.
Whilst searching for pumps on the net I found this; http://www.liquid-levers.com/shop/secti ... 13961dc3df apparently they were the suppliers of hydro pumps to MG Rover in the later days for the MG TF sports car. Looks pretty similar I think. The only thing my pump won't do is create the vacuum to empty the system.
Not sure if this can be added to the how to section as an alternative to Micks.
ImageIMGP9987 by Martin Stanley photography, on Flickr
ImageIMGP9988 by Martin Stanley photography, on Flickr
ImageIMGP9992 by Martin Stanley photography, on Flickr
ImageIMGP9989 by Martin Stanley photography, on Flickr
ImageIMGP9999 by Martin Stanley photography, on Flickr
ImageIMGP0001 by Martin Stanley photography, on Flickr
Photos corrected by mod winabbey
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Tue Dec 30, 2014 9:02 pm
The pictures don't seem to have loaded, I followed the how to upload pictures but they don't seem to be here. Any ideas? The post seems to have gone up twice? Can this be fixed?
PostPosted: Tue Dec 30, 2014 9:23 pm
Try this link for the photos. https://www.flickr.com/photos/martinsta ... 003103842/
PostPosted: Tue Dec 30, 2014 9:26 pm
I think you may have used the wrong link (i use photobucket) but looking at the one that hasnt given an image. Your link doesnt end in an image file type such as xxxxxxxx.jpg
Choose the link/adress copy paste then highlight the link and click img from the tool bar.
You may have used the url link rather than the image link??
PostPosted: Tue Dec 30, 2014 9:46 pm
Had a look, do the following:
Click on image
Bottom r/h corner is an arrow that when hover over says "share this photo", click this
Choose BBCode
Choose size you want
Copy link
paste in ausmini (don't click img from tool bar)
post
should do this
PostPosted: Tue Dec 30, 2014 10:44 pm
Looks good mate.
As an aircraft refueller/mechanic I have used these style pumps for many years to hydrostatic test the refuelling hoses. They are robust and work very well. For an outlay of around $200 this would make a very good, low cost suspension pump.
PostPosted: Wed Dec 31, 2014 2:36 pm
The cost all up was just over $170 which is pretty good value for an excellent quality pump setup. Thanks Bubbacluby I'll try to insert the photos into the original post. I haven't uploaded any photos to the site before.
PostPosted: Tue Mar 03, 2015 7:19 pm
M-JAY, am thinking of purchasing a similar pump set up to yours, was wondering how it is working out for you
PostPosted: Tue Mar 03, 2015 7:34 pm
I like that pump, I never noticed this thread when it was posted.
So having not used one before, is there a bleed down valve? I assume there would be.
50 bar is more than ample!Mine still works fine, but I have more than half an idea to upgrade as this is a little more compact...
PostPosted: Tue Mar 03, 2015 9:09 pm
Oldtimer it worked great. I only used it once to raise the suspension height slightly. It was completely effortless to use, very highly recommended. Mick there are 2 valves and to be honest I can't remember exactly how I used it because I only used it once and that was very briefly. Yes it lets you bleed the system, just not create the vacuum to completely evacuate all the fluid. I am assuming you have an idea.
PostPosted: Tue Mar 03, 2015 9:16 pm
I ended up making one from the cheaper version. Pump was $80 from ebay.
Haven't used it in anger yet so I can't comment on how well it works as a hydrolastic pump.
The gauge has a check valve to hold the pressure when pumping up and a bleed off valve to let off the pressure after. There is also a main ball valve to isolate the hand pump when checking for system leaks.
PostPosted: Tue Mar 03, 2015 9:38 pm
They are a great bit of kit very well built. I pumped liquid through the tube first to prime it before attaching it.
PostPosted: Tue Mar 03, 2015 9:50 pm
How do these pumps last if you leave the fluid sitting in them?
PostPosted: Wed Mar 04, 2015 8:21 am
I have a pump made from a Mini clutch MC. I leave fluid in it all the time.
In the last 20+ years I have replaced the seals, once. The bore was still fine, no pitting.
PostPosted: Wed Mar 04, 2015 8:28 am
Give Ash some flowers Nick .
Has anyone thought about using a valve and one of those vacuum pumps for bleeding brakes to pull a vacuum? How much vacuum do you need to pull on the lines? The amount of vacuum of one of those brake bleeders might be beyond its capability compared to what is actually needed.
