It is currently Fri Jul 18, 2025 10:59 am
PostPosted: Tue Mar 10, 2015 10:37 am
Could someone local please rock around and help Evan light the fire. I would, but I'm too far away... :cry:
PostPosted: Tue Mar 10, 2015 6:05 pm
Did you get it going Evan? I've just seen the post.... I can pop around tomorrow if needed
PostPosted: Tue Mar 10, 2015 8:19 pm
If you light the fire up in that rocket of yours Kev it won't take you long to get up to Evans place :P , consider it a day out :wink: :lol: .
PostPosted: Wed Mar 11, 2015 5:11 am
Still no joy. Bsck to work tiday, so I'm getting a lift. It will have to wait till the weekend.
PostPosted: Fri Mar 13, 2015 9:34 pm
Coil shat itself perhaps?
PostPosted: Sat Mar 14, 2015 7:23 am
Any luck yet Evan ?
PostPosted: Sat Mar 14, 2015 7:24 am
Richard Ashton is coming over this morning. Champion.
PostPosted: Sat Mar 14, 2015 8:22 am
I now think its the alarm. It keeps coming on, even when I don't turn it on - which does immobilise it. How does one remove the alarm from the ignition circuit? I've now noticed a tiny blue wire from the alarm module, where you can key off or on the siren, which has come loose. Can't see where it goes.
PostPosted: Sat Mar 14, 2015 8:37 am
This wire was in one of the holes, but goes nowhere?
PostPosted: Sat Mar 14, 2015 10:22 am
If you put a wire of +side of solenoid to +side on coil will it fire up
PostPosted: Sat Mar 14, 2015 1:36 pm
He speaks! All praise to the Great Richard Ashton who gave up most of his morning to find, much to my embarrassment that the wire on the negative side of the coil had not been crimped (when the engine went back in in July last year) and was just sitting loosely in the sleeve of the connection. It explains the intermittent miss. Barney has now been given a furious run through the back roads of Fullerton cove. Thanks Richard!
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
PostPosted: Sat Mar 14, 2015 2:11 pm
Don't be embarrassed young fella , I think from memory a very similar thing happened to Richards car on the way back from Rylstone last year :wink: , happens to the best of them .
Glad it was an easy fix .
Users browsing this forum: Bill B and 99 guests
