It is currently Fri Jul 18, 2025 9:15 pm
 Post subject: flywheel machining
PostPosted: Wed Mar 11, 2015 7:58 pm
I am going to machine my flywheel in aid of lightening it some,
can anyone please help with a bit of a not what to do if you can?
also wondering if any other mods are required?
I believe some spacers will be required in the clutch pressure plate?
It's easy once you know how.
 Post subject: Re: flywheel machining
PostPosted: Wed Mar 11, 2015 8:29 pm
I was going to do the same in a few weeks. Was going to base it on a thread I found from a while ago.
viewtopic.php?f=2&t=83379&hilit=lightening+flywheel
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Mar 11, 2015 8:33 pm
cheers Scoop, I did a search but got lost in the posts and couldnt find anything solid.
PostPosted: Thu Mar 12, 2015 1:50 pm
Take note off what you machine off the flywheel, because you will have to make spacers up for the bolts so they are at the right height.
PostPosted: Thu Mar 12, 2015 3:45 pm
I remember someone saying take 200 thousands of an inch off and no more.
Users browsing this forum: stewartp and 84 guests
