It is currently Thu Jul 24, 2025 10:37 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Mar 13, 2015 7:30 am
I was thinking that. When you purchase the cable do you get the whole lot?
and am I right in thinking theres the outer metallic spiral shell an another cable inside?? or by outer do you mean the housing around it?
PostPosted: Fri Mar 13, 2015 10:40 am
If you can't undo the knurled nut (because it's awkward) at the bottom of the cable outer, take out the 1/4" bolt that holds the flange below it. Then, remove the lot.
If you need to remove the drive gear, it then just lifts out.
PostPosted: Fri Mar 13, 2015 12:16 pm
apparently thats the way to go to. Easier I heard?
do I need to lift the car up/remove the wheel to do it by reomving the bolt?
PostPosted: Fri Mar 13, 2015 1:12 pm
No. Get it from above.
PostPosted: Fri Mar 13, 2015 3:33 pm
Depending on your pot joint type, access from below is a little too tight for a standard type-A human wrist.
PostPosted: Fri Mar 13, 2015 8:06 pm
Might have to get the local mechanic to do this lol. All I've managed to do is cut myself. I can get the tip of my fingers onto the end of the cable. But caressing and tickling the not isn't gonna get it ofF. There's no way for me to get to the bolt that holds the driver as well. Might be able to if I rip out the rad but I'll just make a mess I'm sure lol
PostPosted: Fri Mar 13, 2015 8:08 pm
No need to do that, a 1/4" Socket set is nearly perfect for the job.
PostPosted: Fri Mar 13, 2015 8:11 pm
Will the 1/4 go on the knurled nut or the bolt holding the drive?
PostPosted: Fri Mar 13, 2015 8:18 pm
For the bolt. Its money well spent, you can use the set just about anywhere on the car with ease. My favorite set of tools.
PostPosted: Fri Mar 13, 2015 8:28 pm
Managed to get nut turning. I'll post pics up. now to try and get it back lol
PostPosted: Fri Mar 13, 2015 9:02 pm
Got it on and wired up. now for the test drive
PostPosted: Fri Mar 13, 2015 9:10 pm
Quick turnaround!
PostPosted: Fri Mar 13, 2015 9:32 pm
surprisingly easy once I found I could get it out using a screw driver inserted into the square cutout on the guard
PostPosted: Fri Mar 13, 2015 9:38 pm
So here's how I managed to do it...
couldnt turn it from the top so I looked around the arch to see if I could reach for it.
someone mentioned I could use a long screw driver and tap it out. I was afraid I would wreck it if it was tight as I couldnt turn it by hand.
was very light to turn though once I used a screw driver. Didnt even need to hammer it. just used the tip to turn the knob
got the old bastard out and used pliers to remove the leftover bit that was stuck in still
got the new one in. Test drove and voila all is well
all I need to fix now are the lights behind the gauge. I accidentally put the oil dummy light into the fuel gauge slot. Otherwise it seems to be ready pretty accurate now.
Time spent procrastinating and saying I was never gonna get it out = about 3 hours
time spent getting it in and out after I found out the screw driver method works = 12 mins. LOL
PostPosted: Sat Mar 14, 2015 5:29 am
I like to wrap a small cable tie around the outer cable near the top to stop the top nut from sliding down into the depths of beyond.
