It is currently Sun Jul 27, 2025 9:06 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat May 21, 2005 4:55 pm
This is funny crap............ i have a benny hill theme in my head just thinking about it :lol:
I got nuthin......................
PostPosted: Sat May 21, 2005 5:00 pm
Hang on Don't you poor the Oil in Via the Dip Stick :!:
 Post subject: Drivers Left
PostPosted: Sat May 21, 2005 5:32 pm
OK put the LF wheel on the brick! Know which one that is...? :?
Doc ...thats why we call Drivers Left or Right at the Car Raisen....
even for left hand drive cars :oops: ...makes it impossible to get it wrong :D
PostPosted: Sat May 21, 2005 5:46 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
you could always go get a drill and put a few holes in the gearbox caseing and then drain it then fill the holes with silastic
makka
PostPosted: Sat May 21, 2005 6:16 pm
You can suck the oil out quicker if the oil is thin, so warm up the oil by lighting a fire under the sump. This will also remove any oil that has leaked under the motor.
 Post subject: Yes you can.....
PostPosted: Sat May 21, 2005 6:19 pm
Car rental places sometimes use this method....suck the oil out of the sump thru the dipstick tube and force a new charge in just like they do for an auto trans....
I once took a Pontiac Grandam in for a service in the states....the staff apologised because the service took about 15 minutes :!: :shock:
PostPosted: Sat May 21, 2005 6:27 pm
No you silly person, you pour the oil in the big hole in the rocker cover,
and then wait for it to come out the dipstick hole...... how else would you know if it was full or not. :D
Craig
PostPosted: Sat May 21, 2005 6:52 pm
Craig
That what I though, I have no Line's on My dipstick so it was full once it had a Miniscas on the dipstick sharft :wink:
PostPosted: Sat May 21, 2005 10:11 pm
another tip find another mini owner in advance, who is also doing the same job . then you already have someone to change oil with.. that way you will have enough oil for them and they will have enough oil for you..
PostPosted: Sat May 21, 2005 10:23 pm
I used to drain the oil out of mine, then tip it into my son's Clubbie. It ran on the total loss system- :lol: got through about 1L every 200 miles.. :shock:
PostPosted: Sat May 21, 2005 11:08 pm
ok drained oil tonight, need to get the new filter tomorrow and put some new oil in. how much are the bolt on filters, and can you get them from supercheapo or a place like that???
Potato
PostPosted: Sun May 22, 2005 6:55 am
Does it have the old type cartridge filter (Ryco R2200P) in a canister, with a bolt in the bottom? You won't find those at SuperCrap...
OTOH, they do keep the Valvoline VO22 spin-on ones (same as Toyota camry V6), but I think they are $11 or so. Too friggin' dear for me. I buy elsewhere, unless they are on special.
PostPosted: Sun May 22, 2005 8:54 am
I'm more interested in the chilli sauce issue. Any particular brand?
I assume theres an SAE rating on the side of the sauce bottle that I've never noticed :-)
thinking it would make a fantastic marinade.. chilli engine oil. Fantastic for salads, bbq's etc.
David
PostPosted: Sun May 22, 2005 1:53 pm
ok doc, where can i get one then???? mine is the bolt on canister one. or should i just not bother, also do u have to put oil through it before and flush the rest out again before the final oiling....? someone sed u have to?
Potato
PostPosted: Sun May 22, 2005 2:22 pm
Don't bother flushing, does more harm than good. If motor is that dirty, do an oil change, run it 100 miles or so, do another... :lol:
If you don't know when filter was last done, do it!
1. Undo bolt and take the can & its contents off.
2. pull the cartridge out and chuck it. There might be a separate metal plate under the cartridge if it's an early one- if so keep the plate.
There are 2 slightly different cartridges (with plate- without plate)- buy the right one to replace it.
3. remove the bolt. Inside the can there]s a spring, flat washer and seal washer. Keep 'em.
4. Wash out the can with degreaser, kero or whatever.
5. Get a small screwdriver and scrape the seal ring out from the filter head. Make sure it's all out, don't damage the groove.
6. Fit new seal ring in there. Comes with the filter cartridge.
7. Put bolt up into can. Fit spring, flat washer, seal washer inside, in that order. Fit plate (if separate) and filter cartridge.
8. Bung it all back onto the filter head, make sure the can sits in the groove, on the seal ring. Tighten the bolt.
9. Change the oil (if not done already).
10. Start the motor and check for leaks.
8)
Users browsing this forum: No registered users and 70 guests
