It is currently Thu Jul 24, 2025 10:33 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Mar 14, 2015 7:20 am
I like to wrap a small cable tie around the outer cable near the top to stop the top nut from sliding down into the depths of beyond.
Yep , saves a lot of heartache :wink: , especially when you think you've done ok getting the bottom one on , then you
look to screw the top one on and it's no where to be seen :evil: .
PostPosted: Mon Mar 16, 2015 5:52 am
Small update : Speedo now in but at first it was squeaking loudly. Probably as the cable turned. Moved the cable a bit so it's quiet down. But still slight audible sjueak at the gauge end. Why?????
PostPosted: Mon Mar 16, 2015 7:21 am
The modern cables made wherever now are often assembled dry as the proverbial. Sometimes with free rust inside too.
Pull the inner cable up, smear some molygrease on it (NOT the top 100mm) and refit.
If grease gets into the speedo head you will have other problems.
PostPosted: Mon Mar 16, 2015 7:36 am
Doc...my work here is done :lol: Excellent advice 8)
PostPosted: Wed Mar 18, 2015 11:27 am
DavidE wrote:
1071 S wrote:
What a shame ... their website is still active... Do we have another choice??
Cheer, Ian
Not that I am aware of locally.
There used to be a place at Blacktown but whether that still exists is not known to me.
These guys are still going... in St Marys.
http://www.attspeedautoinstruments.com/
PostPosted: Wed Mar 18, 2015 11:35 am
might get them to freshen mine up. i quite like the 'upgraded' from pov pack look lol
PostPosted: Thu Mar 19, 2015 2:28 pm
and Ralph maybe able to help as well...
http://www.generalauto.com.au/index.htm
Users browsing this forum: timmy201 and 103 guests
