It is currently Sat Jul 19, 2025 1:09 am
 Post subject: Priming oil pump
PostPosted: Thu Mar 26, 2015 12:25 pm
Hi all.
Is it possible to prime the oil pump by jacking up the front of the car and turning one of the wheels backwards whilst in 4th?
Garage is small so I can't really roll it back far...
 Post subject: Re: Priming oil pump
PostPosted: Thu Mar 26, 2015 1:22 pm
Yes, jack 1 side up and put the handbrake on. Works fine. Also good for adjusting the rockers, etc.
PostPosted: Thu Mar 26, 2015 1:39 pm
Thanks doc. Will give it a go.
So I shortly found out can't do it with both wheels of the ground. Something to do with the diff I take.
PostPosted: Thu Mar 26, 2015 1:43 pm
That is correct. It needs 1 wheel on the deck, unless you are running an LSD.
PostPosted: Thu Mar 26, 2015 3:18 pm
Done.
For future reference, all this priming stuff also helps diagnose if you have a stuck clutch plate (which I didn't but thought I had with 2 noob wheels of the ground). If the wheel freely turns backwards without resistance, it could be that the clutch plate is stuck due to long term storage.
