It is currently Mon Jul 28, 2025 4:00 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Rear seat belts
PostPosted: Thu Apr 02, 2015 2:48 pm
Hanra
In an attempt to be more helpful your mates 71 HQ is after the dates quoted in this thread therefore should have them. My fathers 71 HQ kingswood wagon had them from the factory, but I think Holden might be out of stock now.
PostPosted: Thu Apr 02, 2015 2:58 pm
I know here in wa. Pre 69 vehicles have no legal obligation to have rear belts engineered when fitted. My 68 deluxe I have welded in the complete rear shelf from a clubman and my 67 is gonna get some heavy reinforcement done before fitting.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Apr 02, 2015 3:07 pm
A couple of things that may be of interest.
Front seat belt mounting points were incorporated in the Mini body during production long before the ADR was introduced. Below is a page from the Driver's Handbook TP757a dated March 1966.
Also below is the factory drawing detailing the installation of later style belts in the Mini (primarily in the Clubman). These are effectively the instructions to the seat belt installers to ensure they were fitted correctly and consistently on the production line.
PostPosted: Thu Apr 02, 2015 3:12 pm
Did they provide any guidance on the positioning of the holes in the parcel tray?
PostPosted: Thu Apr 02, 2015 3:51 pm
Hanra wrote:
My mate is having a hard time finding a genuine set for his 71 HQ GTS Coupe, and I wondered if the reason that was, was due to the fact it didn't come out with any as was not required.
My parents had a 1971 HQ Premier and it had rear belts, chrome buckles with a black button with the embossed lion Holden emblem.
The tongue was chrome with a rectangular slot that was useful as a bottle opener.
PostPosted: Thu Apr 02, 2015 3:53 pm
The rear parcel shelf engineering drawing would show that. I'll see if I can find it.
In the installation drawing I posted earlier it is assumed that mounting points are already part of the body shell, that's why there isn't any dimensional data showing their precise location.
PostPosted: Thu Apr 02, 2015 3:55 pm
Certainly for the front, but not the rear. My 62 has the belt mounts for example, and it won't have been the first.
Thanks Doug.
PostPosted: Thu Apr 02, 2015 4:04 pm
Yes, you are correct (that's why I intentionally mentioned front in the post with the handbook image). :wink:
Here's the back parcel shelf drawing. You can see the angled reinforcement bars added for strength, and the position of the seat belt mounting points.
PostPosted: Thu Apr 02, 2015 4:06 pm
Your blood's worth bottling Doug, thanks again.
PostPosted: Thu Apr 02, 2015 4:25 pm
Cheers mate, yep that sounds like them. He mentioned the front ones that he has have the lion on the buckle, but from 72 onwards they had GM on them apparently? The 71 belts might be similar to the HG belts perhaps?
PostPosted: Thu Apr 02, 2015 4:26 pm
Mick wrote:
Your blood's worth bottling Doug ...
That's exactly what my wife often says. :)
Here's a picture of her I took during a recent storm. She wanted to know why I had moved her coffin so I could get my Mini in out of the rain.
... and, in case anyone wonders what I look like, below is my passport photo. :shock:
PostPosted: Thu Apr 02, 2015 6:55 pm
I am in the process of fitting rear lap only seat belts. Already have captive 2 nuts welded in the centre.
has anyone got photos of where i can put plate and captive nut on the outside was told by my mechanic wheel arches are the best.
PostPosted: Thu Apr 02, 2015 7:17 pm
If you do a search on the words rear seat belt there's quite a few threads with some good info. Perhaps a lot of padding and repeats to get to the juicy bits but still worthwhile for anyone about to do this on their vehicle.
Here's some pictures (mostly courtesy of Morris 1100 from another thread) showing the factory rear seat belt fittings. As your mechanic said, the outside ones are in the wheel arches.
PostPosted: Thu Apr 02, 2015 7:26 pm
Thanks winabbey
that's what i have been looking for. have done search on this site and other mini site no luck.
the mounting point is where i thought just back from rear pocket in wheel arch so nut does not to foul on Tyre
PostPosted: Thu Apr 02, 2015 7:49 pm
Watch the length of those rear wheel arch bolts.
I've been caught twice before with the bolts gouging the sidewalls of my tyres. There's not as much room as you might expect under there.
