It is currently Thu Jul 24, 2025 11:25 am
 Post subject: Engine number?
PostPosted: Fri Apr 10, 2015 4:20 pm
Hi there,
Im wondering if anybody can help please?
I cant seem to find the engine number of a car Im looking at tomrrow.
Its; 99H702ViH2100. Im not sure if its an i or a 1.
Owner tells me its a 1100cc, but I just want to make sure.
Ive tried a few motor decoders without luck.
Thanks guys.
 Post subject: Re: Engine number?
PostPosted: Fri Apr 10, 2015 4:31 pm
The 99 at the start would suggest it is a 998 block.
It may well have been fitted with a 1098 crank and pistons at some stage however..
PostPosted: Fri Apr 10, 2015 4:36 pm
99 means 998.
Unless it has had the crankshaft changed it is a 998.
PostPosted: Fri Apr 10, 2015 5:53 pm
Ok thanks guys.
So im guessing if its a differant crank it would increase the stroke = more cc's?
He also said has been bored 40thou with flat top pistons and lumpy cam.
We will get more info in the morning.
PostPosted: Fri Apr 10, 2015 6:03 pm
You can stick an 1100 crank in a 998. They are the same block.
PostPosted: Fri Apr 10, 2015 7:09 pm
But you need 1100 pistons too, the pin height is 3.75mm different. But conrods are the same.
PostPosted: Sat Apr 11, 2015 9:26 pm
Thanks again. It indeed have a 1100 crank put in it..........eitherway we bought it and it sounded great!
Users browsing this forum: Bing [Bot] and 103 guests
