It is currently Wed Jul 23, 2025 12:35 pm
 Post subject: subframes
PostPosted: Fri Apr 10, 2015 5:43 pm
Just checking I can swap both front and rear subframe from a round nose to a moke?
 Post subject: Re: subframes
PostPosted: Fri Apr 10, 2015 5:46 pm
Yes but front may have mounts for moke bumper and sump guard depending on the model, rear trailing arms are longer on the moke but rear subframes the same.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Fri Apr 10, 2015 6:16 pm
Wasnt worried about the sump gaurd but true about the Bumper brackets. I will use the moke subs. Didn't realize the trailing arms are longer so must use them ;)
Did I hear rite you were selling the Rebels?
PostPosted: Fri Apr 10, 2015 8:00 pm
Yes sold them, boomini now has them.
Easy enough to get some mounts fabricated up and welded to a mini subframe, I did that with my recent resto as the original subframe was well and truely munted.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Fri Apr 10, 2015 9:10 pm
If you're leaving the moke on 10's (or 12's/13's with low profile tyres that fit on a mini) then you don't have to worry about the trailing arms. They only made them longer to clear the big chunky 13's.
PostPosted: Sat Apr 11, 2015 1:49 pm
its a little wheeler but the longer the better. ill measure and see if they are long otherwise Ill just swap everything over once the frames are painted
PostPosted: Sat Apr 11, 2015 2:17 pm
I don't think long arms fit a little wheeler..?
PostPosted: Sat Apr 11, 2015 3:19 pm
Little wheelers have Mini trailing arms.
PostPosted: Sat Apr 11, 2015 4:47 pm
The Mini King
When the longer trailing arms were fitted to the Moke, The Rear Guard was changed at the very rear of the Moke to accommodate the larger wheels. 10 inch wheel Moke the rear Guard was vertical, and on the Big wheel Moke the rear guard was angled. The EXPORT Moke rear guards were stepped
PostPosted: Mon Apr 13, 2015 8:08 am
Hmmmm maybe I have got a big wheeler then
PostPosted: Mon Apr 13, 2015 3:38 pm
Yeah but they look better on 10's :-)
Users browsing this forum: Bing [Bot] and 91 guests
