It is currently Sat Jul 19, 2025 4:26 pm
 Post subject: coolant bypass hole
PostPosted: Wed Apr 22, 2015 12:15 pm
Hi guys I have read the posts on blocking the coolant bypass hole.What are the pros & cons of doing this & do most engines have this mod done these days.Also I need a new radiator for my Cooper S.What is the best radiator to add extra cooling ie. 2, 3 or 4core ? I dont want aluminium as I am trying to keep origional appearance.
 Post subject: Re: coolant bypass hole
PostPosted: Wed Apr 22, 2015 12:21 pm
Only advantage of blocking the bypass is there is 1 less hose to blow. But they don't blow unless you use the concertina type (which S doesn't use, they run heater hose there).
If buying a new radiator I would get the UK super 2 core.
The UK 4 core is good too. May need body or shroud trimming to fit, I can't remember.
The `Cooper' UK cheap 3 core made my motor run hotter than the stock Oz one. I'd not use it on a 1275 or bigger.
PostPosted: Wed Apr 22, 2015 12:23 pm
I've had mine blocked for 15+ years, no issues
Especially as originality is a concern, I suggest getting your current radiator cleaned out (tanks removed and cores cleaned) rather than buying a new one or getting it recored. If your existing radiator is too far gone, try to buy another one in good condition and have that cleaned out.
PostPosted: Wed Apr 22, 2015 4:21 pm
So the radiators supplied by Minisport that look pretty origional are not that good as far as origionallity goes?
PostPosted: Wed Apr 22, 2015 4:40 pm
They are not identical to an Oz made one, no.
Oz Cooper S, Deluxe, Mini K & MiniMatic all had an Oz made 3 core radiator with 16 gills (fins)/inch in the core.
The UK Cooper one I bought some years ago for our 1293 only had 8 fins/inch. They may have changed this since.
PostPosted: Wed Apr 22, 2015 5:31 pm
I have a couple of spares down here. I think one in particular will clean up quite well if you wish.
PostPosted: Wed Apr 22, 2015 9:03 pm
Thanks for the help Mick,I think I will go with a new radiator as the motor & associated parts are new.
Users browsing this forum: drmini in aust, watsupskip and 87 guests
