It is currently Mon Jul 21, 2025 10:41 am
 Post subject: Rear subframe bushes
PostPosted: Fri Apr 24, 2015 10:30 pm
I purchased a rear subframe poly bush kit from minisport and received four bushes with internal ribs in the hole and four without ribs just a plane hole. Does anyone know which goes where ? Thanks
 Post subject: Re: Rear subframe bushes
PostPosted: Sun Apr 26, 2015 8:57 am
Hmm I didn't notice any difference in the eight poly rear subframe bushes, I thought they were all the same from memory? I may be mistaken but as far as my experience goes, they should all be the same.
The only pic of poly bushes I could find
PostPosted: Mon Apr 27, 2015 9:30 am
I agree, have a looks...
PostPosted: Mon Apr 27, 2015 3:04 pm
Ha - well bugger me. Maybe someone else knows? Otherwise Tony/John/Andrew at Minisport would be able to let you know what the go is. I actually just got off the phone to them. If I'd had this in mind I could have asked.
Maybe post up any new info when you get it.
PostPosted: Mon Apr 27, 2015 4:21 pm
I've not seen them ribbed before, I was hoping someone else has. As far as I know they're all meant to be the same.
They're not greased so its not a channel for grease to pass through, and I don't see the point of having stiff and brittle urethane bushes, only to have move around under load on the ribs. I honestly don't know where they're from.
What did Minisport say?
PostPosted: Mon Apr 27, 2015 4:42 pm
Ribbed...
For her pleasure...?
:shock: :lol:
PostPosted: Mon Apr 27, 2015 5:06 pm
I sent Minisport an email but have not heard anything.
PostPosted: Mon Apr 27, 2015 5:11 pm
I've had a look and Minisport UK sells these ribbed. There's no description why, maybe to stop them sticking to the mount, maybe to allow some wiggle.
http://www.minisport.com/spdsp662a-upra ... -1976.html
PostPosted: Mon Apr 27, 2015 5:30 pm
Mick wrote:
I've had a look and Minisport UK sells these ribbed. There's no description why, maybe to stop them sticking to the mount, maybe to allow some wiggle. I don't know why you would want wiggle however, so probably not.
PostPosted: Mon Apr 27, 2015 8:58 pm
Does this help ?
This is from the latest MiniWorld regarding installing a front sub frame.
PostPosted: Tue Apr 28, 2015 8:28 am
Maybe the people supplying them might know. Nolathane or the likes.
Usually the ribs are for the greased type. These aren't the same bushes used in early model front lower control arms? They're bigger aren't they?
Is it an optical illusion, or are they different sizes?
Mini spares sell the ribbed ones specially for the UK market, it's for the rust to grow into. :-) :-) :-)
PostPosted: Tue Apr 28, 2015 8:46 am
If you want em to last like originals did, I'd fit rubber instead. I find polyurethane doesn't last well in most applications.
PostPosted: Tue Apr 28, 2015 9:06 am
+1 on that, they've lasted this long.
PostPosted: Tue Apr 28, 2015 9:18 am
Great in theory, however new rubber is NOWHERE near the quality of that of 40+ years ago.
PostPosted: Tue Apr 28, 2015 10:44 am
That's why you don't the Chinese plasrubber bits.
Users browsing this forum: BrisbaneMini and 96 guests
