It is currently Sat Jul 19, 2025 8:40 am
 Post subject: Re: Brake problem
PostPosted: Thu Apr 23, 2015 1:09 pm
Cooked pads.....yess please.... many sports pads are "extended cooked" at the factory to remove the volatiles from the mix once the pads are pressed. Unless the pads are crumbling, they are fine.
PostPosted: Thu Apr 23, 2015 3:10 pm
http://www.mossmotors.com/SiteGraphics/ ... discs.html
You can repeat the bedding process to clean up the discs and pads, however new ones are cheap and less hastle.
PostPosted: Sat Apr 25, 2015 5:26 am
How are the brakes coming?
PostPosted: Sat Apr 25, 2015 10:29 am
Hi all
Picked up some ebc pads yesterday. Average weather here today, so hope for a test drive tomorrow.
Thinking hoses and master cylinder next....
PostPosted: Sun Apr 26, 2015 4:26 pm
Hi all
A very satisfying day in the garage today. Found this.....
Calliper "halfs" had been swapped! Only one piston per calliper was being actuated!
To think the previous owner told me all mini's had poor brakes....
Should I worry about the score in the disc? Or just add it to the list of things to do in the future?
PostPosted: Sun Apr 26, 2015 4:29 pm
That is pure gold!
Swap em over and see how it goes.
I wouldn't worry about the score till the pads wear out.
PostPosted: Sun Apr 26, 2015 4:31 pm
Oh crap!
PostPosted: Sun Apr 26, 2015 5:10 pm
Good find !
glad you found that , you should be a lot happier when you put them back together the right way
Mark
PostPosted: Sun Apr 26, 2015 5:44 pm
Good work there. Wouldn't worry about the score in the rotor, just put it back together and bleed it back up.
As good as new again!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Apr 26, 2015 7:14 pm
Reassembled, fluid changed and bled.
Eventful test drive.... Brakes worked well, but ran out of fuel lol. 5 min walk home for jerry can.
Next job... Tidy bodged wiring behind binnacle, including fuel guage. ;)
PostPosted: Sun Apr 26, 2015 8:07 pm
wow - that could have taken years and a LOT of $$ to find!
must've been putting some crazy stress on the rotor with it only pushing from one side like that
PostPosted: Sun Apr 26, 2015 9:01 pm
Great initiative to pull the caliper apart and inspect.
Nice to have working brakes :)
And +1 for not worrying about that rotor damage.
Happy days!
