It is currently Sat Jul 19, 2025 12:53 am
 Post subject: Resto, what to do
PostPosted: Sun Mar 29, 2015 3:28 pm
Hi Guys, I am restoring a 1978 1275 LS and am not sure whether to fit new rubber cones or put springs in. I would like to stay as close as possible to original but it would cost less to do springs and last longer.
What do you think i should do? :idea:
1978 Leyland Mini 1275 LS
Hi Ho Silver and hopefully away
 Post subject: Re: Resto, what to do
PostPosted: Sun Mar 29, 2015 3:39 pm
What ever works best for you and your intended use for the car, its a mini not a Rolls Royce and unless you are going for Con courses restoration add mod touches if it improves the car reliability safety or performance. I know there are plenty who are hung up on originality, and hey if that is thing all power to you but me I drive my cars and if I can make it faster safer more reliable then why not
Rubber.
PostPosted: Sun Mar 29, 2015 5:13 pm
Lots of people will tell you springs are better, others will say new cones are better. I've never tried springs. I swapped out my old front cones for some second hand rear cones. Decent second hand cones can still be fine, and with the new shocks and hilos it's a nice smooth ride (for a mini, anyway). The second hand cones cost me $30.
Remember, the original cones have lasted this long - some minis are still getting around on 40+ year old cones. Good cones do last - just don't go for the $30 no-name ones. Get good new dunlop rubber cones, or go for good condition old ones.
PostPosted: Sun Mar 29, 2015 6:35 pm
I'm doing a resto now and swapped the front to rear and side to side. The front had sagged pretty badly as they do in a 38 year old car. Hopefully when it goes back together the car will sit slightly lower and level. I've never tried springs but I say stick to rubber.
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Sun Mar 29, 2015 7:27 pm
Many years ago I had Japanese Delta springs. The thing I didn't like about them was that they didn't feel progressive like rubber and because they don't have as much natural damping as rubber I had to wind the shock absorbers up to the point of being pretty unpleasant and a little unpredictable to drive (and I really like driving go-karts).
I could have tried harder to make them work and I've since read that adding a front and rear ARB improves them a lot but then you've got to ask if you really want to spend a whole lot more money to 'improve' something that isn't broken... And I really like minis on rubber cones - just feels right - MS red dot ones are so much better than pancaked 40 year old cones too.
PostPosted: Sun Mar 29, 2015 7:58 pm
Let's not reinvent the wheel all these years later.
Do as Sir Alec intended!
PostPosted: Mon Mar 30, 2015 9:59 am
There are good rubber cones and there are bad ones.
Both Karcraft and Minikingdomonline sell good ones. Other shops here do too. Around $90 - $100 ea.
Avoid the cheapies, you do get what you pay for.
[edit]
I'd fit Hi-Los too. Again, there are good and bad. The ones Karcraft and `TheMiniMan' sell are CNC machined from alloy billet, here in Oz. Not cheap imported sand cast rubbish.
PostPosted: Sun Apr 26, 2015 8:35 am
Thanks guys. I decided to go with rubber.
PostPosted: Sun Apr 26, 2015 7:15 pm
Good choice.
If you want a smoother ride then check out the Minisport Smootha-Ride kit.
My car feels smoother than a hydro mini.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
Users browsing this forum: Bing [Bot] and 95 guests
