It is currently Sat Jul 19, 2025 4:42 pm
PostPosted: Mon Apr 27, 2015 12:28 am
Hi all
I'm having a bit of trouble removing the door hinges from the newly acquired 76 rust bucket, specifically the segment that attaches to the body.
Advice is greatly appreciated.
Eiles
PostPosted: Mon Apr 27, 2015 1:57 am
7/16 socket, swivels, extensions, spanners..
Its a crap of a job eiles. ..
There is two bolts/nut under the wheel arch per hinge. Bottom ones are easy.. top ones are hard.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Mon Apr 27, 2015 2:34 am
If you're just looking to get the doors off you can always centre punch and drill out the hinge pins too.
PostPosted: Mon Apr 27, 2015 8:31 am
I use an old 7/16 dwarf ring/OE spanner, with the ring end thinned down and a bend put in the shank.
PostPosted: Mon Apr 27, 2015 10:45 am
A 1/4" Sidchrome Socket set is the greatest toolset you can own when you are doing work on Minis. This is certainly one of those jobs.
PostPosted: Mon Apr 27, 2015 12:01 pm
If you're really lucky, once you dig all the dirt out from behind and finally get some purchase on the nut, the little 1/4" studs will just shear, and the hinges will literally fall off.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Apr 27, 2015 12:31 pm
... or the stud will unscrew from the bracket rather than the nut undoing. Regardless it can be repaired via various methods.
PostPosted: Mon Apr 27, 2015 12:51 pm
Thanks for the all detailed replies. :D
Ill have a go this arvo.
I'm trying to pull off all the bits worth saving as replacement/spares for the 77 mini.
I definitely need better tools.
Eiles
PostPosted: Mon Apr 27, 2015 2:10 pm
If youre scrapping the shell why not cut the A-panel off, then they're easy to remove.
PostPosted: Mon Apr 27, 2015 7:32 pm
I remember when I took my door hinges off my 76 clubby. I wish i had known it wasn't an actual bolt but a nut and a stud. 6 hours of swearing later, I figured it out why the socket wasn't seating on the nut...
-----Better is the enemy of good-----
-1976 Yellow Devil Leyland Clubman-
-1970 Morris Mini Van - Work in progress-
