It is currently Sat Aug 02, 2025 12:53 pm
 Post subject: Re: penrite oil
PostPosted: Mon Apr 27, 2015 10:56 am
Should be OK, 10w/40 is commonly used overseas.
PostPosted: Mon Apr 27, 2015 3:21 pm
Location: MinisintheGong [Somewhere on the South Coast]
I emailed Penrite and got to communicating with a tech. I am using Penrite Classic Light specifically designed for layed up engines. A good thread though becasue i have registered that particular car last month and its headed for a fresh oil change.
It may be dearer but i got the Penrite on special. Its a good point to buy Australian made.
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
PostPosted: Mon Apr 27, 2015 5:46 pm
I find this thread quite interesting, I have always used the HPR30 since getting my mini, but maybe I should try something else.
My engine and box is a little sick and when cold it sometimes refuses to go into second gear and clonks/crunches into others even when crawling - the box itself isn't great but it has gotten worse since the weather has started cooling down.
On a manual 4 synch box, would the difference between 20w60 (hpr30) and 20or25w50 alter the smoothness of gear change? Or is it very minimal? I'm just trying to nurse it until the other engine can be built
James
PostPosted: Mon Apr 27, 2015 6:51 pm
I think most 20W (whether /50 or /60) oils are much the same when cold. I found the Castrol Edge 25W/50 to be a bit stiffer on the shifting in winter, but at $50 a can I don't use it now.
PostPosted: Tue Apr 28, 2015 6:38 pm
Repco 30% off sales help. I usually stock up when these weekend specials are advertised
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Apr 29, 2015 11:00 am
Whats a bottle of the Penrite Mini oil worth?
PostPosted: Sat May 02, 2015 8:06 pm
Penrite and Gulf Western are the same oil. Both come from the same plant and are owned by the same parent company.
Cheers Pete
