It is currently Mon Jun 23, 2025 11:57 pm
Post new topic Reply to topic  [ 130 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Tue Apr 28, 2015 7:50 pm
Well I could use enough for a Morris 1100 which is about the same as two Minis, so I'm in for two lots.
PostPosted: Tue Apr 28, 2015 7:51 pm
To be honest... i think its to big i had a similar one.
PostPosted: Tue Apr 28, 2015 7:55 pm
Where do you think it's too big?
Also where did you get the one you say was similar, do you have any left for comparison?
PostPosted: Tue Apr 28, 2015 8:10 pm
I'm still ok for 1 car
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Apr 28, 2015 9:00 pm
I got somefrom a mob in brisbane. I'll have a look in the shed tomorrow.
PostPosted: Wed Apr 29, 2015 8:23 pm
This is the stuff that def doesn't shut on my doors.....
This is the original stuff, does Fit and door shuts
Comparison
PostPosted: Wed Apr 29, 2015 8:28 pm
the non original is 1mm wider, but as you can see its much more rounder and the hole is bigger... if that makes sense
PostPosted: Sat May 23, 2015 3:20 pm
Brett, is there any way you an do the following measurements accurately, interested in the difference.
Also, when you tried this seal did you use original pinch mould. I ask this because the original pinch mould and was it install the right way around (it has an inside and an outside edge) If it was not original or the wrong way round it could add to the thickness?
I have a feeling that is the same as the stuff I was looking at. :(
PostPosted: Sun May 24, 2015 9:48 am
Don't have any of those fancy tools. But I'll go and see if i can get them?
PostPosted: Sun May 24, 2015 9:51 am
Yes i used the orignal pinchweld
PostPosted: Sun May 24, 2015 12:06 pm
How can 1 or 2mm Stop your door from closing?
I'm puzzled how that could be.
I mean doors will close with seatbelt hanging out the door......
PostPosted: Sun May 24, 2015 2:19 pm
It binds up at the fromt
PostPosted: Wed Jul 15, 2015 9:11 pm
Hi Phillb - what is the latest on this exercise?
PostPosted: Thu Jul 16, 2015 9:18 am
I was hoping Brett could take some more accurate measurements.
I've been desperately busy with work so haven't been able to follow up much more
Last week I ordered one of the modern seals that is pinch mould and rubber combined (from mini king) to replace my passenger side one. I can now see that the tolerances are very fine. The new seal makes it quite a bit harder to close the door. I'm sure it will settle in but just goes to show there's not much in it.
It seems that what Brett tried is the same product I was looking into. Certainly looks the same.
PostPosted: Sat Jul 18, 2015 12:13 pm
Hi Phill
I have been watching to see what the out come is on this post and at this point I would have to agree with Brett.
I have been down the same road with the new rubber trim. The doors will close and I used silacon on the rubber to help but it is still too much pressure on the door to allow it to close as it should.
I was lucky to find new old stock, Pinch weld and rubber and the difference is that you can close the door with ease using the door handle.
The Rubber has to be thinner than the new rubber shown in your photo's but of the same mould to fit the pinch weld.
Measure the sample I sent you to compared to the new rubber and you will find it is that 1mm to 2mm thicker.
Maybe finding a manufacture is the only answer for a group purchase.
Regards Pete.
Users browsing this forum: wickedwazza and 97 guests
