It is currently Mon Jul 21, 2025 5:38 pm
 Post subject: cam recommendations
PostPosted: Sun May 03, 2015 11:25 pm
Hey guys wanting to puchase a cam and have no idea what to buy.
My engine is a a+ 1275 bored 20thou.
Lightened and balanced bottom end.
Lightened flywheel. Running I beleive a tad over 10to1 compression. It has maniflow 3 into 1 extractors and a hif 44 carb. Im getting a head done atm but it will be std valves with a bit of porting done to inprove flow.
Id really like something lumpy and give more top end.
What would any of you super knowledgeable people recommend?
Cheers in advance
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
 Post subject: Re: cam recommendations
PostPosted: Mon May 04, 2015 3:25 am
I've run a 286SP cam from Kent Cams in a similar spec engine (except I was using a 45mm Weber) and it made it a hoot to drive.
That said, as I'm sure you're aware, Graham Russell is considered by many to be the Australian mini cam guru - might be worth giving him a call to see what he recommends.
PostPosted: Mon May 04, 2015 8:07 am
Contact APT - http://www.aptfast.com/ListItems/MainCa ... hafts.aspx
David Anton will design and grind a cam to suit your engine requirements.
Have a Nice Day.
PostPosted: Mon May 04, 2015 2:04 pm
Hey Rod,
I run a Piper BP285 cam in my 1100S +100thou. Pretty hard to get it to idle nicely, but pulls like a 14 yr old with a playboy when it gets above 2000rpm.
Keels.
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Mon May 04, 2015 3:02 pm
I have a GR 286i, idle is lumpy at 1200rpm and pulls like a train from 3500 to 7000rpm. Not recommended for a daily driver though. But I love it.
PostPosted: Mon May 04, 2015 4:49 pm
What are your plans with the engine Rodney?
A daily driver that will see traffic?
A weekend warrior or a weekend cruiser?
Also, how do you plan to drive it?
These are the sort of questions you need to ask yourself before you make your decision. Everyone will tell you his cam is great and it does this from this rpm to that rpm, but it really come down to what you want to do with the engine. Once you make that decision, your cam choice will be easier to make.
Once you know your cam then you can have your head modified to suit, as your cam determines the head specs!
Cheers Shane
PostPosted: Mon May 04, 2015 4:53 pm
Cheers Shane
His plans are, he wants it lumpy and better top end. The cam I have fits the bill, that's why I posted my recommendation.
PostPosted: Mon May 04, 2015 6:31 pm
I have a Kent 276 cam for sale. Brand new still in its sealed packet.
Have a read up about it and let me know if you're interested.
PostPosted: Mon May 04, 2015 8:18 pm
Cheers Shane
Are you running stock valves in your head with the 286i? If so then your car would be the perfect one to check out.
It's a pretty aggressive cam and yes it is definitely a bit lumpy and goes ballistic from 3500 - 7000+ but as Shane said, the cam needs to match the head and vice versa to get the best out of it.
I'm no mechanic though, just chucking in my limited experience.
PostPosted: Mon May 04, 2015 8:41 pm
Cheers Shane
Yep stock mk1 big valve head and stock 1.5 roller tip rockers and stock fully throated and ported. :oops:
PostPosted: Mon May 04, 2015 8:44 pm
Haha what a coincidence! Mines stock as a Brock too! ;)
Users browsing this forum: fuzzy-hair-man and 72 guests
