It is currently Tue Jun 24, 2025 5:54 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 23, 2005 8:15 am
Online
If you're buying a 240V MIG welder- the more voltage adjustment steps it has, the better. Mine is stepless (SCR control).. that's the best of the lot. :D
<edit> apart from inverter MIGs that cost $BIG.
PostPosted: Mon May 23, 2005 10:08 am
I have a Telwin 150 amp MIG, which I've used a fair bit. It's reasonably priced and works well. The tutor at the welding course I did said they trialled them and thought they are pretty good. You wouldn't buy one for a panelbeater, but I'm guessing people would use it much as I do, for Minis and other projects, not full time use. It's a lot cheaper than a Lincoln, only has 4 heat seetings but I like it.
I tend to prefer brand new over second hand through experience. Gasless MIG is, as far as I can tell, a waste of time unless you can't get gas. Automatic visors are handy, you can get an automatic filter for a normal mask which is cheaper. But the best thing is a good course. I did 18 weeks @ 2/hrs a week, and learnt stick, mig, tig, gas, plasma and gas cutting, bronze welding - all for NZ$360 inc materials. Loved it.
PostPosted: Mon May 23, 2005 10:14 am
All 240 volt welders switch off and on during the sine wave cycle due to them being single phase. Three phase machines don't do this and as such are a far easier welder to use. I have always used 3 phase welders and wondered why I initially had problems when i tried to weld with a stick single phase welder and it took a few minutes to get used to Also don't operate a welder on the end of a long extension lead as it loses voltage that way.
Chris
Everything I like is either
PostPosted: Mon May 23, 2005 11:53 am
Yeah, 3 phase is nice but not exactly an 'at home' option... but if I win Lotto, I'm hooking up, buying a TIG and making a nuclear reactor...
PostPosted: Mon May 23, 2005 12:36 pm
I got my WIA 150 amp MIG out of the paper for $300 a few years back. It's been good to me.
