It is currently Tue Jul 22, 2025 1:50 am
 Post subject: Output seals
PostPosted: Tue May 12, 2015 9:20 am
Any tips on how to get these out without damaging the covers. I've tried levering them with a screwdriver but there stuck fast. Cheers. Image
 Post subject: Re: Output seals
PostPosted: Tue May 12, 2015 9:59 am
Grab flange in the vice,
Use big flat screwdriver to lever it out.
PostPosted: Tue May 12, 2015 10:27 am
Yep, what the doc said. Or maybe you could also attack them from the back as well.
I changed mine while still bolted to the case, so they just levered out.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Tue May 12, 2015 1:29 pm
Got the buggers out. Ended up using a small jemmy bar. They were glued in I think.
PostPosted: Tue May 12, 2015 1:53 pm
No need to glue them with anything. They are rubber coated; fit them dry and they seal, and don't slide about.
PostPosted: Tue May 12, 2015 2:00 pm
Will do, thanks Kevin.
Users browsing this forum: No registered users and 118 guests
