It is currently Wed Jul 30, 2025 2:12 am
 Post subject: Timing Chain Sets
PostPosted: Tue May 19, 2015 8:07 pm
For tunnel bored blocks Rollmaster make CS8000 +5 or CS8000+10
Due to my steel centre main fitted I have some options
Hope this helps someone
 Post subject: Re: Timing Chain Sets
PostPosted: Wed May 20, 2015 8:09 pm
If you mean line bored main bearings, that is handy to know.
michael
PostPosted: Wed May 20, 2015 9:40 pm
Good to know.
I did up an S block years ago that already had the mains tunnel height up .016" from stock. I decked .016" off the flange and used an Iwis duplex chain, A+ front plate, tensioner and a 9deg offset cam key. The Rollmaster kit would have helped.
PostPosted: Thu May 21, 2015 2:51 pm
Are these sets ex stock or made to order.
The reason I ask is, I enquiried the availability of these thru the NZ agent & they said they were NLA.
Do you have a contact at Rollmaster I can use as reference
Are they only +005 & +010 sizes, nothing smaller
Do they cost more than the std rollmaster set?
PostPosted: Fri May 22, 2015 11:37 am
Not sure on price.This is the reply I got from Nornda or Romac who make them.
Hi Ian
Our part number is CS8000 +5 or CS8000 +10.
Regards Stan
This is very good news. The website shows how to measure the slack in a new standard chain to determine which one you need.
http://www.romac.com.au/Tunnel_Bores.html
PostPosted: Fri May 22, 2015 6:50 pm
Hi Ian
Regards Stan
You'd want to pull your finger out and do some work on this car these may be NLA by the time you think about getting this car on the road as well paint engine bay inside the boot petrol tanks etc
PostPosted: Fri May 22, 2015 8:29 pm
Onya Rob .That's what mates are for .
PostPosted: Fri May 22, 2015 8:58 pm
You know me never let a chance go by lmao
Users browsing this forum: No registered users and 65 guests
