It is currently Wed Jul 23, 2025 11:35 am
PostPosted: Thu Jun 04, 2015 10:10 pm
I want to screw in 2 barb fittings into my manifold for a PCV setup and I am not sure what size threads would be in the manifold.
Probably BSP or NPT. (Because all my taps are UNC/UNF/Metric) :lol:
Does anyone know for sure what thread size they would be? I am hoping to get the old plugs out without damaging the manifold but they have been glued in really well. So I can't measure the size and TPI.
This is the type of manifold http://www.redlineauto.com.au/p-138-red ... XA7DmAw8aI
Here is a photo showing the 2 plugs in there at the moment. Cheers Brad
PostPosted: Thu Jun 04, 2015 10:16 pm
5/8-18 UNF.
it's around 1mm smaller than a 3/8 BSP. I put the 3/8 BSP barb or nipple or hex plug in the lathe, turn it down to 5/8" and run a 5/8 UNF die nut down it. The BSP thread was 19tpi, the UNF thread cleans it up fine.
I tend to use a solid brass 3/8 BSP hex plug, make it 5/8 UNF then tap it 1/4 BSP and use 1/4 brass fittings.
The other way to fix it is run a 3/8 BSP tap into the manifold, but I prefer leaving the threads in it original.
[edit] some newer Redline 3005 manifolds are tapped 1/4 BSP.
Here's one I piped up recently, for a servo and a Toyota PCV valve.
PostPosted: Thu Jun 04, 2015 10:37 pm
Thanks Doc.
I guess the first thing is to get the plugs out and see what damage that causes. I will probably just go for the easy way out with a BSP tap. I have a few of the 3/8BSP barbs that go into airtools etc.
PostPosted: Tue Jun 09, 2015 9:16 pm
All done. They were 1/4 BSP so I just used a couple of air tool fittings.
PostPosted: Tue Jun 09, 2015 10:24 pm
Looks good.
Some people say you should not run any balance pipe on a Weber manifold, and just hook the pcv valve to one port. But I find on a road car, the idle is better with one fitted. As with a PCV valve on 1 port only, you need to run that side richer at idle.
PostPosted: Tue Jun 09, 2015 10:55 pm
Looks good.
Exactly why I went with the 2 ports.
Its slowly getting there. It used to have a 5L oil bottle as a catch can. Now it has a charcoal canister for a more standard look. The hoses I used were left over from my sprinkler system and hold water pressure fine.
Users browsing this forum: kirby and 91 guests
