It is currently Wed Jul 30, 2025 3:32 pm
Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Mon Jun 08, 2015 10:32 am
7b Mk2 steering wheel (about 69-mid 70's have no idea when changed)
7c aftermarket steering wheel
8a and
9a lights and buckets will fit ALL minis mokes and some other cars
9b headlight retaining rings - will fit all round nose and moke, NOT clubman
11a generators (dates will tell you yr model they are)
11b look like 15ac alternators. Fitted to most clubmans and Leyland minis
11D will have a part number on it, people will be able to tell you what its from, from this
PostPosted: Mon Jun 08, 2015 10:42 am
11c is late Phomy dizzy cap, 2x screws hold it on instead of the usual spring-clips
I`ll be happy to buy the moke sports steering wheel (7c) off you if you`re interested ?
PostPosted: Mon Jun 08, 2015 11:50 am
When is this stuff going on eBay :?:
PostPosted: Mon Jun 08, 2015 11:55 am
Suggest you put the Moke mud flaps on eBay too. They are hard to come by (if original).
PostPosted: Mon Jun 08, 2015 1:48 pm
7A = Morris 1100 Steering wheel and column.
10A = Lucas starters up till mid 70s.
10B = Lucas starters from the mid 70s on.
Nearly all electrical parts will have dates and part numbers stamped on them.
PostPosted: Mon Jun 08, 2015 5:24 pm
I can see 4ZR on the radio. I grew up with 4ZR.
PostPosted: Mon Jun 08, 2015 8:04 pm
8a and
Thanks, I'll try and dig them out again for the part number. Ha ha, only just finished packing all this stuff neatly to the side of the shed as I need the room. Was bound to happen :roll:
Thanks
Ohh, at this stage whilst trying to sort through what I have and need I'll keep it for now......
But, more that likely though all Moke parts will at least be moved on when I'm done.
As above, I'll more than likely hold onto this stuff until I'm finished sorting through it and know exactly what I need.
Thanks all for all your feedback.
More photos to come!
PostPosted: Mon Jun 08, 2015 8:08 pm
Just googled 4ZR as never heard of it, seems you grew up in Roma, QLD?
PostPosted: Mon Jun 08, 2015 8:17 pm
Some more pictures guys.
12. Speedo's, Instrument panels/surrounds
13. Hub caps
14. Manifolds (2 x styles/sizes) & Carbies (3 x sizes?)
15. Oil filters?
:wink:
PostPosted: Mon Jun 08, 2015 8:46 pm
12A Speedo, Mini 850
12B Speedo binnacle, Early Moke, 66 to 69 (or thereabouts!)
12C Early Moke that has been played with
12D Clubman/Leyland Mini
12E Binnacles, 850/Deluxe/Cooper S Mk1, etc, quite hard to find undamaged ones
13A Hubcaps, Mini Cooper, there are two types, early and late, the difference is the shape of the holes, I don't remember which came first!
13B Hubcap, Mini, nearly every model except the Cooper and Clubman and a couple of others.
14A Manifold, Most Minis till 75 and the Morris 1100 as well.
14B Manifold, Top one is a Mini from about 76 on, the lower one is Morris 1100S from 67 to 69 or Morris 1300 from 69 to 72.
14C same as 14A but with a carby, a HS2 SU.
14D Carby, SU HS6, Austin 1800
14E Carby, SU HS4, Morris 1100S
15A Oil filters, look like Ryco fitted to Australian cars between 65 and 74.
PostPosted: Tue Jun 09, 2015 7:10 pm
Thanks mate, that's awesome!
PostPosted: Tue Jun 09, 2015 7:26 pm
Some more parts for ID.
16. Rocker covers, heads, rocker gear, filters & bearings
16D Head has various markings - 8CAM 4004 2 J7 B
16E Head markings are - 12G202 6 M2
16F Head has various markings - MO 21086 MOWOG 2A3
* Have more photos of the heads if need be? *
17. NEW Piston & Rings 040 + Cam. What can be said about this Cam?
PostPosted: Tue Jun 09, 2015 7:40 pm
16A looks like Mini 850.
16B looks like a late 70s type (probably goes with 16D)
16C looks like a Morris 1100.
16D = Late 70s air injected pollution head.
The oil filters all look like the Purolator UK type that was fitted to the 850/Cooper and Cooper S.
16H is a Ryco early type.
16I is a felt type that was fitted to the Cooper S.
16J is a Unipart early type but the box is the Ryco later type.
PostPosted: Thu Jun 11, 2015 3:36 pm
Thanks Morris 1100 :)
Anyone have any other ideas about the Head 16E & Head 16F pictured? 16E (12G202) looks to have far bigger ports on the side of the head.
Also 17B cam, would these cam profiles be suitable for mild street use?
PostPosted: Thu Jun 11, 2015 3:49 pm
This has been really good and very informative, thanks to all the contributers. Hope others are also getting use out of these too?
Some more photos for ID
18. Cam, Crank (12A1451 - Engines fitted, size?), Shocks (will they fit all Mini's) & Clutch (also, will they fit all 998 & 1098?)
This particular crank seems to have notches cut out from the counterweighs, is this normal?
19. Asst fans - metal & plastic, fitment?, air assemblies 1 x metal & 2 x plastic also, radiator
20. Steering racks & hubs. All models?
Cheers.
Users browsing this forum: slacko and 81 guests
