It is currently Tue Jul 22, 2025 6:34 pm
 Post subject: MEMS Diag
PostPosted: Sun Jun 07, 2015 6:14 pm
just found this
http://memsdiag.blogspot.de/
maybe helpfull for some of you.
i tried the lite version, and it works with my MEMS 1.6 test bench, but not with MEMS 1.3. thats no surprise as the software only supports MEMS 1.6 and 1.9.
will get an adapter for MEMS 1.9 soon and test is, too
Rover 214 atm ....
 Post subject: Re: MEMS Diag
PostPosted: Mon Jun 08, 2015 11:54 am
Nice find KLAS :D
PostPosted: Wed Jun 10, 2015 12:33 am
got a cheap KKL interface to connect to the OBD connector used on later cars. it works, too. not always on the first try, but if you keep touching "connect" it finally will connect and run ok.
got in contact with the developer and he will have a look regarding MEMS 1.3. not the most common ECU, but always nice to have it included.
and i'm hoping for a bluetooth version
Rover 214 atm ....
PostPosted: Wed Jun 10, 2015 10:15 am
Bluetooth? Remapping whilst on the Autobahn...love it!
PostPosted: Wed Jun 10, 2015 4:20 pm
sadly true remapping is not possible due to ECU design.
but you can adjust a bit. or log the data to check for an intermittent failure
Rover 214 atm ....
