It is currently Sat Jul 19, 2025 3:17 pm
 Post subject: What Welder Do You Use
PostPosted: Thu Jun 11, 2015 3:43 pm
Hi Guys and Girls
I'm in the process for replacing all the rust in my mini. I have a SIP Mig gas/gas-less welder. I have used mig and arc welders in the past, but I can never get the welder to weld the same every time. I thought I might be my lack of skill, so i got my nephew who is a boiler maker to have ago with both gas and gas-less, he got it a lot better but still not the best, he pretty much gave up.
So my dilemma is I want to buy an new / second hand welder that will hopefully help me to improve my skills and wondered what brands and model that had found the best. Ideally I would like to stay under $500 but I also know you get what you pay for.
Dave
PostPosted: Thu Jun 11, 2015 3:55 pm
http://www.ebay.com.au/itm/Smootharc-Mu ... 3f32c150f6
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Thu Jun 11, 2015 6:02 pm
Hey - I recently bought a Bossweld MIG 186. From Gas Weld. For I think $400 ish (I'd have to check). Here is the link to the product website.
http://www.dynaweld.com.au/mig-welding- ... g-186.html
FYI the product for some reason is not on the GasWeld website.
PostPosted: Thu Jun 11, 2015 6:11 pm
Ditto. I got the exact same. I havent fired it up yet though (due to time and my plans needed approving).
1963 850 - laid up
PostPosted: Thu Jun 11, 2015 6:49 pm
Ever get déjà vu braad? :)
PostPosted: Thu Jun 11, 2015 9:19 pm
I have a SIP gas/gasless welder.
I find it OK to use. I run it on a higher setting than you might expect.
I use it with Gas. Didn't like the finish/flux removal with gasless.
PostPosted: Thu Jun 11, 2015 9:58 pm
I've had an SIP gas gasless thing for a few years now and it has never worked properly, neither did my brother in laws. It is utterly the worst piece of junk that I have ever used. I even gave it to the welders at my wifes work to try and fix but it still didn't work properly. I have been looking at welders for my next project. Make sure that your chosen machine goes down low enough to weld thin metal. The Boss machine mentioned above I felt didn't go down low enough neither did the BOC one mentioned above, if I remember correctly. I looked at CIGweld and seem to remember it not going low enough either. The only machine that did was the Lincoln Electric Powermig 180c that goes down to 30 amps. But it is about $900. I spoke with one of the welders at my wifes work about it all and he said go with any big brand name at your local welding place and spend as much as you can afford. He said to avoid machines with digital displays, like the BOC machine above, because when you use gasless outside in the sun the display heats up and goes blank then stuffs your welding settings up. This happened to a friend of his. I'm interested to hear what the people above think to their Boss machines, they go down to 59amps.
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Thu Jun 11, 2015 10:09 pm
I have an ozito one that goes down to 40 amps but the drive is a little sketchy. Works ok but anything less than setting 8/9 (of 10) the wire doesn't feed the pool quickly enough. And the gun leaks shielding gas which is annoying me to death.
PostPosted: Thu Jun 11, 2015 10:16 pm
I've learnt my lesson on cheap welders. As they say "Pay now and don't pay later".
PostPosted: Thu Jun 11, 2015 10:21 pm
Try this page it's a pretty good source of info. http://www.mig-welding.co.uk/buying.htm The section ' How many amps minimum' is pretty informative.
PostPosted: Thu Jun 11, 2015 10:25 pm
I run a 25? year old Kemppi 150A Super Kempomat. Torch is a genuine Binzel MB15.
Made in Finland... has no fan, coz up there it's too cold to need one! :)
[puts welding engineer's hat on]
@69K1100...
Pull the gun's liner out, soak it in a tub of thinners then blow all the crap out. Or go buy a new liner, they are cheap & don't last forever.
Also, make sure the feed rolls are wiped clean, and have a gap between them with the wire in. If no gap, they have had it and won't grip the wire to feed properly.
PostPosted: Thu Jun 11, 2015 10:34 pm
Thanks for the replys guys, I will keep looking into it all and see how I go. My nephew cleaned it out but mostly the torch. But I will try again
Dave
PostPosted: Fri Jun 12, 2015 12:50 am
Hi just purchased Cigweld 135. Gas and gasless from supercheap for $299 on promo. The unit can get down to 30 odd amps for thin metal. Has 4 amp settings and wire speed adjust.
PostPosted: Fri Jun 12, 2015 6:25 am
175 cig transmig, very nice machine
1993 R32 Nissan Skyline GTR
PostPosted: Fri Jun 12, 2015 7:57 am
With any MIG machine, the switch positions are for volts, not amps. Wire feed rate = amps. Double the wire speed, and you (basically) double the amps.
Voltage controls the arc length, and also affects the mode of metal transfer across the arc. Low voltage = `short arc' transfer, high voltage = `spray arc' transfer (if your machine is big enough...) :wink:
The machine holds the set voltage (which is why they are called constant voltage) and varies the output amps to maintain the arc length.
Go down in wire diameter eg from 0.9 to 0.8, and the amps will be less, at the same wire speed.
Clear as mud??? :lol:
Users browsing this forum: No registered users and 67 guests
