It is currently Thu Aug 14, 2025 12:02 am
PostPosted: Thu Jun 11, 2015 12:25 pm
Hi all,
I am currently rebuilding my rod change box. New bearings and the main shaft overhauled by a well known mini expert. It's all back together but for some reason, once I fitted the laygear it won't turn.
I have put gears in neutral but it only turns 3 or so teeth then locks. It is all very clean and I can't see what's causing the problem. Here are some pics. Please help. Cheers, Richard.
PostPosted: Thu Jun 11, 2015 1:03 pm
try a screwdriver behind syncros, just to make sure theyrenot sticking on cones?
PostPosted: Thu Jun 11, 2015 2:55 pm
peterb wrote:
try a screwdriver behind syncros, just to make sure they're not sticking on cones?
This.
If it's been put in 1st & 4th gears to lock it, both synchro cones are probably still stuck on their tapers. Even though it's now in neutral.
PostPosted: Thu Jun 11, 2015 3:38 pm
All good now, must have been the syncros. Thanks guys.
PostPosted: Thu Jun 11, 2015 4:36 pm
hows that, 2 syncronised answers fixed it.
PostPosted: Thu Jun 11, 2015 6:36 pm
Everybody in sync :)
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Thu Jun 11, 2015 9:11 pm
is it just me, or are the dogs on that 1st motion shaft absolutely rooted?
PostPosted: Thu Jun 11, 2015 10:12 pm
The accuracy of the grinding of the dogs was never the best so they're always a little uneven. The pic quality is too low for me to pick anything wrong.
PostPosted: Fri Jun 12, 2015 2:00 pm
Here's a closer pic, not new at all but still look serviceable to me.
PostPosted: Fri Jun 12, 2015 10:51 pm
ah cool, sorry was just the photo :)
PostPosted: Sun Jun 14, 2015 11:13 am
Does anybody have a picture of how the selector shaft lines up with the plates that move the forks. I can't work out how it fits. I'm learning lot's :)
PostPosted: Sun Jun 14, 2015 1:32 pm
Here's one I prepared earlier :wink:
In Neutral
.... and in First Gear
Curly
PostPosted: Sun Jun 14, 2015 1:39 pm
That one's a remote though.
The rod change is similar though. The three swivel plate pieces should each have a slot for the selector rod and all 3 slots should line up when all the gears are unselected. Then by carefully moving and turning the selector rod and it's interlock sleeve you should be able to rotate them into the swivel plate slots. Best done before the diff cover goes on.
PostPosted: Sun Jun 14, 2015 2:20 pm
Yep I'm sure I've been going the right way but I just can't get the sleve to rotate all the way... I'll keep at it. Cheers. Richard.
Users browsing this forum: No registered users and 315 guests
