It is currently Tue Jul 22, 2025 3:07 pm
 Post subject: starter motor problems
PostPosted: Wed Jun 24, 2015 8:29 pm
Starter has been making a grating noise engaging. so i pulled it out and found shavings, obviously from ring gear. starter seams to be operating ok on the bench. but does sound noisy to me.
Although i dont know how it should sound. :?
Any Ideas
here is a video
PostPosted: Thu Jun 25, 2015 12:43 pm
First check the bushes the shaft runs on mainly drive end. You will need to pull the bendix spring off and remove the drive from shaft. Check that the part of the drive barrel that is visible as 4 Dogs from the side is not broken at 4 spots.
"Let us remove your "SHORTS"
PostPosted: Thu Jun 25, 2015 7:00 pm
I check the condition of the teeth. it doesn't look good. only a new ring gear.
PostPosted: Thu Jun 25, 2015 7:10 pm
I wouldn't worry about the ring gear too much.
Start off by following Tony's advice is my advice
PostPosted: Thu Jun 25, 2015 7:23 pm
to add insult to injury. i had another mirror and dropped it and some shards have gone into the housing can you remove the cover with out taking the engine out? :oops:
PostPosted: Thu Jun 25, 2015 8:25 pm
You just need to undo the engine mount, jack up that side of the engine off the subframe and once unbolted the cover comes out.
PostPosted: Thu Jun 25, 2015 10:05 pm
Thanks
PostPosted: Fri Jun 26, 2015 5:11 am
Also check you have correct ring gear for the type of starter, inertia and pre-engaged have different tooth counts
PostPosted: Fri Jun 26, 2015 5:53 am
are they a same number of teeth with different profile or vise versa.
how can i check which one i have.
PostPosted: Fri Jun 26, 2015 6:13 am
ring gear for inertia starter = 107 teeth
ring gear for pre-engaged starter = 129 teeth
PostPosted: Fri Jun 26, 2015 7:11 am
I don't think current new ring gears are as hard as they used to be.
One I fitted recently to a friend's 1377 stroker is badly marked (chewed) on entry all the way round, after 2600km with a new Lucas starter. [edit] The starter pinion is unmarked.
No, I didn't get it blue when fitting...!
Owner is gonna fit a Gemini starter to it now, they are pre-engaged and mesh in from the front.
