It is currently Mon Jul 21, 2025 1:53 pm
PostPosted: Sat Jun 27, 2015 4:16 pm
Hi Guys
I have 8.4 inch discs on my MK1 from a metro and I was wondering since its been converted over to disc brakes can I put 7.5 inch discs by just removing the old rotor and calliper and keep the fittings that I have on there now or do I need new hub, brake lines and so on, the reason for this is im going to put 10 inch wheels on it. Your help would be much appreciated.
PostPosted: Sat Jun 27, 2015 4:29 pm
This is what you will need. Do the brake hoses and copper washers as well.
https://www.minispares.com/product/Clas ... 013MS.aspx
PostPosted: Sat Jun 27, 2015 6:12 pm
I have done the conversion using the kit above from minispares, I also replaced the rear wheel cylinders to the 5/8 bore Cooper S ones
PostPosted: Sat Jun 27, 2015 6:49 pm
I've also done this but got my kit from Karcraft.
Also changed the rear cylinder to 5/8".
PostPosted: Sat Jun 27, 2015 9:51 pm
I have the 7.9 inch disc brake setup with 10 inch wheels and wish to swap to vented 8.4 and 13 in wheels, maybe we should talk?
PostPosted: Sat Jun 27, 2015 10:02 pm
Metro hubs are different around where the outer wheel bearing seal fits and the casting isn't cleaned up as well where the disc actually sits because 8.4's sit a little further out. You may need to (as I have in the past) carefully grind away the metal getting in the way but it is possible :)
Users browsing this forum: No registered users and 61 guests
